20 Most Recent
Sylvania 6720FDD 20 in. TV/VCR/DVD Combo Questions & Answers
There is no sound.
Hello
The possibilities for this fault are many. The first one is the damaged speaker. Just place your ears very close to the speaker side of the TV and switch it ON by its main power ON/OFF switch, and listen whether there is any "thumb" sound can be heard from the speaker. If there is; the speaker is OK and audio output section circuits in your TV has the trouble. The output IC and it surround components should be checked. As the set was working with an other audio system, before you buy it, the audio filter section inside the TV is alright. If 'Mute" function is ON, there will be no sound. In your TV, this function may be ON, becuse the party whom you bought this set was using its audio out to feed his amplifier. Normally, thsy will activate the MUTE of the TV, to make it silent. Ask them whether they ahve done it. If so, you have to set the MUTE of OFF. In most Sylvania sets, this can't be done without a remote. OK.
I have a sylvania 110 voltage and was used in a
Either you got lucky and just the few blew inside. Or worst case is the power inverter blew and will have to be replaced. You can test the inverter with a voltmeter. You can look at the glass bus fuse itself to see if it is bad or not.
Line across the tv no sound no picture
If you look carefully at teh line it should be red, green, and blue close together to appear like a white line. If this is the case, then the vertical circuit has failed. This is often poor solder connections at the vertical IC or a defective IC. Expect a parts cost in the $20 range for this repair.
Dan
Sylvania MTS/SAP tv/vcr/dvd combo turning itself off
could be that either the dvd or the vcr are malfunctioning, usually it is the vcr that creates the problem. If you turn tv on and set vol to low see if you can hear the noise of the motor loading or trying to load,with out a tape inside. It may be a good idea to have a qualified tech repair it, these units are difficult to work on and further problems may come up if you are not familiar with the tv.
Tv comes on then goes right back off
If your vcr has a tape stuck ( or mechanism out of timing ) the set will turn itself off. Same for the DVD mechanism. It's usually the vcr. good luck
Dvd tray is stuck and will not open
On most models, there is a small hole on the side of the tray. If you straighten out a paper clip and stick one end into this hole and push, it should manually open the tray.
