20 Most Recent
Fuji FinePix S304 Digital Camera Questions & Answers
Fuji Zoom Error Message
Ronald,
There is no easy fix, you?ll have either disassemble and get dirty, or take to an authorized repair person. This zoom error problem is usually caused due to dirt or dust in the zoom mechanism.
If you think you can handle disassembling the camera then grab a set of gentile screwdrivers and follow these instructions:
You will have to remove a few circuit boards in order to get to the zoom mechanism.
Fuji finepix s3100has no power even with new batteries
I have this problem also with Fuji Z90 model.Problem is fixed and focus now working ok.Camera is fall down and after when camera was started giving sound click click from focus big motor and error on screen Focus error Focus ( lens ) was open ( small cover on top bellow sticker ) Small "snail" gear is taked out . Two sliding segment adjusted
for focus ( upper full up and lower full down - beware about spring inside below this focus pins )and snail is inserted back. Camera started and focus start
working. I need to make small adjustment . Reason when camera is
started picture is not clear and before using camera i need to do full
zoom in and back zoom out. After this picture is crystal clear and all
working ok.
Getting an zoom error on
Lens errors (zoom errors on Fuji's) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But,
here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
I have installed the CD rom, but when connecting the camera to the PC nothing happens. What is wrong?
Try NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as
Picasa.
I cant download my images
You don't need any special software. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program, such as iPhoto and Windows Photo Gallery.
I put my pics on
Did you make any changes on the card when you had it in the computer? It could just be that the card is no longer compatible with the camera. this can usually be resolved by formatting the card on the camera itself. Unfortunately, this will delete all the images on the card so make sure you back it up first. Hope this helps!
Hiram
Photo Tech Repair Service
110 East 13th Street
New York, NY 10003
212-673-8400
What is Old Telephone Repair
i need to know to!!!!!!!!! everyone is talking about how it fixed their camera, but i dont know what it is or how to use it! so the answer would be helpful, thanks!
How to get computer to recognise digital camera
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
I want to delete pictures but i keep getting told
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Finepix j38 zoom error
I Fixed mine a few times what i did was turn it on it would scope out and back hold it and keep it from going to back in then go to pictures then exit it should be working fine now
What is a zoom error on a j38
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the
probability is that you will have to get it fixed by a professional.
Use
these at own risk as it may further damage the camera.
Firstly ,
try connecting your ac adapter or usb cable.
Try holding the
shutter button while switching on the camera.
Look at the lens ,
and if some of the lens 'circles' is misaligned or not concentric then
try wiggling it (while holding camera lens down).
Try gently
pushing or pulling the lens when it extends but this is risky as it may
cause the lens barrel to slip out of its guidance system.
Another
way to do this is to place the camera lens down on a hard surface and
then power it up. Be sure to use a soft cloth or something similar as to
not scratch your lens or casing. Let the lens push the camera up and
down a few times and sometimes the little resistance provided by the
camera is enough to get things going again.
Try hitting your
camera near the lens on the body with the soft tissue on the palm of
your hand.
Other than that , I would take the camera to a repair
center for a evaluation to see if it would cost more to repair than to
replace the camera.
If it is still under warranty I would suggest
you take it in before trying any of these steps and remove any
off-brand batteries or accessories as some stores are really fussy about
warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope
the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
