20 Most Recent
Fuji FinePix 6800 Zoom Digital Camera Questions & Answers
Want to change language japanes to eng
On page 92 of the manual is how to change the language. That only works when your software (Firmware) contains the language you want to use. If the camera came from Japan, most chance the language in the camera is Japanese only. You could try to register the camera and than ask Fuji if they can give you the right firmware. Sometimes they offer firmware updates. In such a case you must choose the one with the correct language.
link to the manual of this camera.
Lens cover stuck open, power wont come on
I have been told by a camera mechanic i contacted on line (in America) that there is a fuse within the camera which is very small and soldered onto one of the boards. I was unable to get a precise location and the only details were that this component was either white with black writing or black with white writing.This may have a bearing on your problem.
Dennis
I have not used my
May be you inserted a memory card formatted with your PC. Format the memory card using the Format function in the camera menu. Format function can be found in the setup menu of the camera.
If this does not work, try replacing the memory card.
How to download picture to pc from camers
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
How to delete photos from camera manualy not
Bring up the picture you want to delete and press the button with the garbage can icon..follow the on-screen instructions. To erase the entire card, just go into the menu and find "format"...follow the on-screen instructions.
I can not use it as a webcam
The webcan function requires a driver especially for this purpose. It is no longer included in the windows drivers. I'd recommend you forget the project and instead buy a cheap webcam. The 6800 was not much good as webcam anyway. The pictures were to dark in normal indoor light.
