20 Most Recent
Emerson EWC1303 13 in. TV/VCR Combo Questions & Answers
Tv turns itself off after bout ten seconds
Your over voltage circuits(hi-voltage and low voltage) are defective.When the voltage exceeds the specs it shuts off the tv.Unless your a service tech,you can't fix this.There are components on the main circuit tha t have to be changed.Sorry, no easy fix.
Emerson TV/VCR Combo mODEL ewc1303/a
You have built-in features that correspond between the TV and The Hand held controller designed by Emerson. Universal remotes are lacking some features that are necessary for full function of the TB. In your case, you may be required to replace the hand held unit with another exactly alike and with all of the functions you are accustomed to.
How to add channels
Try doing the auto scan first to get all the possible channels.. Usually the Add/Delete function applies once the TV knows what channels are out there to add or delete.
Hi, my tv has suddenly
I would just replace the TV unless you have the skill and tools required to fix the problem with the old one.
CASSETTE STUCK IN VCR WONT EJECT I TURN VCR ON IT STAYS
turn on the machine. use your figure push on the cassette, when you feel the cassette can't go any farther (don't jam it),and hold it there. press the eject button, you may have to try this couple of times in order for the cassette to come out.
the cassette deck need to have the drive belt change.
Need code for emerson LD195EMX to program dish
This first link provides the procedure on how to
program the remote
http://www.mydish.com/support/program-to-tv-code-non-basic?WT.svl=contentArea This second link will provide you the codes needed to program the remote to the
TV (The top line would be your remote model # you will find this number on the
back of your remote, make sure that is the one you enter)
http://www.mydish.com/support/apps/remotecodes.aspx?WT.svl=leftnav
If you need further assistance please let me know. Once you have obtained the
codes that can address to your television you follow this procedure to program
the remote. (Which is the procedure provided on the first link)
Press and hold the clear TV button at the top left hand side of your remote for
5 seconds (all the other clear buttons will light up) once this happens enter
the code followed by the # button on your remote, the clear TV button at the
top will light up 3 times, this means the remote has been programmed. You can
verify the remote has been programmed by trying to up the Volume, once you
verify it works be sure to press the SAT button at the top left once (to set
remote back to SAT mode and avoid other problems) Feel free to contact me at:
[email protected] if
you need further assistance.Kimberly EscobarSocial Media RepresentativeDISH L.L.C
Want to remove closed caption
Hi:
Check on your remote for a button labeled CC or check you setup meny under setup for the closed captioned option and set to off posistion.
When on button is pressed( on the remote or TV)
Hello
If your other TVs work on the same antenna, and only this Emerson doesn't work with it, eiter your TVs tuner inside, or it tuning has some trouble. Check by put the set to autotune refering to its user manual. Check whether the cable socket is tight or not.
If these are correct, replace its tuner, [it is inside the circuit board], with same type and number. OK.
TURN ON THE SET AND IT WILL SHUT OFF IN ABOUT 10
You may find a bad capacitor near the powerline regulator. This powerline regulator will have an STR-XXXX number. And if that is not enough, you will surely have two or three resistors that have changed values. These combonation TVs are very, very difficult to keep operating. You may have a service person repair this....and then in a month the TV will act up again. This is good advice. You decide what to do next. Thanks for asking and show a few hands of support.
