20 Most Recent
CTX EzBook V92C266 Notebook Questions & Answers
Software for baleyo
I need softwares for my micro laptop baleyo.my micro laptop ko mouse area is not working also
Victory service manual
umm ok is this for a victory Motor cycle? if its not i would need model number to get it for you
I HAVE a ez net book it wont keep acharge
If the notebook battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Its not boot the os
operating system have corrupted and you need to reinstall windows again and also check for BIOS setting, make sure first boot is from internal hard disk
Ezbook lost password wont to wipe computer
Why wipe it? As long as the drive isn't encrypted you can just blank out the password. Download and burn Hiren Boot CD to a disc. Put it in this laptop and make sure boot to CD is first in your boot order in BIOS. Then follow the video.
I have a new ezbook pc windows embedded CE6.0 and
as a owner of one try this
!/go to internent op,then in your sercuty ,inable all the boxes
@/do this in local and trusted also
now that you have done that there is a box above delete your brower history hit the little arrow and chose same as pocket pc
oh one more thing/in your advancesettings be sur to select always send urls and allow page transition
now that is done turn the wi fi on and wait for your net work then connect on it go down and hit oka.
if that dosent work read the part in the manual for connecting to the wifi
leave the settings as i gave you earlergood luck
Wont turn on just says on screen loading os
HELLO FRIEND, ALL YOU HAVE TO DO IS TO RESTORE YOUR OPERATING SYSTEM TO THE FACTORY SETTINGS, IF YOU HAVE THE CD'S WITH YOU. OR FORMATE IT WITH THE OPERATING SYSTEM CD THAT U WANT.
