20 Most Recent
Philips TP2784C TV Questions & Answers
Remote clone
If
you wish to buy its original remote control, you have to contact the authorized
service center. If you wish to buy a
universal remote control, you should know about, which brand remote control
have setup code to your TV/device brand. You should first make sure about the
number of digits in the codes to your device have. There are 3-digit, 4-digit, 5-digit and even 2-digit codes. You
can get this detail by the code list attached to every universal remote
control. The brand name of the remote
control you select isn't a matter; but, its code list should have setup codes
to your TV/device brand, otherwise you can't set it up with your device. Check out, which brand remote control has
setup codes to your TV/Device brand.
Setup code list & setup procedure to some popular brand remote controls
are given. Check it, and determine
which brand remote control should be bought, and buy that brand remote control,
according to availability.
Check the sites linked here.
Set-up code list, and Set-up procedure to many popular brand remote
controls are given.
http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to
Mosaic
/ Timeslide, can be selected by the
drop-down list, by the top left
of the display window, will make surf easy.
How do I turn off closed caption on Model TP2784C101?
If the remote control have a "CC" button on it, press it once to cose the Closed Caption option. If the remote do not have a 'CC" button, enter TVs menu option, surf through, come towards closed caption adjus window, and make clsed caption function to OFF, if it is ON.
On my remote every time I turn tv on it goes off
Sounds like the power button on either the remote is not releasing when you take your finger off the button. Or the circuit board is starting to go bad on the remote. here is one thing you can do. you can take the remote apart carefully remembering how it goes back together and clean the shell and the pad only don't get the circuit board wet but if you do let it dry for a day before putting it back together (this is the way I do it.) or you can buy a universal remote to replace the old one.
I have a Sanyo ds20424
I don't think there is no reset switch inside the TV but may be FUSE blown deu to power intruption pls check the fuse and if it gone peplace the fuse with same rating
Philips TP2784C TV Manual Download
Download Philips TP2784C TV Manual
Would
you like to review the features of the Philips TP2784C TV?
Have
you lost your Philips TP2784C TV Owner's Guide?
Would
you like a free digital, searchable, pdf version of the Philips TP2784C TV Manual?
Follow this link (& click
FREE)
to download a pdf version of the Philips TP2784C TV documentation.
I
hope that helps.
___________________________________________________
I don't have my original remote. I want to watch a
Unfortunately, that function is simply too advanced to access any other way but through an
appropriate remote control unit. As this is such a highly sought TV by audiophiles who want an excellent listening experience for their older audio-DVDs, this remote control is readily available. One can buy a replacement, either a used
original remote (model RCU81B) for between $8- $40 on eBay and other such sites, or
brand new, for between $30- $35 through several different remote
replacement companies. Simply search the words "Philips Magnavox
RCU81B" to locate such sellers. You also have the choice of buying a clone- brand new,
of course- for around $20. Most sellers of remotes on sites like eBay do warrant their used products, so there is no real reason not to go that route.
I just ran a
quick check of an eBay seller with a $7.99 original remote, and not only
does it look great, but it comes with a 100% guarantee. To
get full functionality of your TV back, especially for one that offers
as options as the TP2784C, that is a very small amount of money to pay. The seller
even offers a "Best Offer" option, so who knows, you might try offering him $5 and see if he is willing to go for it!
Need Unlock channels
I called Philips Magnavox at 1 888 744 5477 and they told me the default ACCESS CODE number is 0711. It works on my TV though it didn't solve MY problem of the TV defaulting to Chanel 9 every time I turn it on. Drats. Hope this helps.
No remote, channels locked on smart tv
On this set, the volume buttons are the same as the menu button on your remote. The two channel buttons work the same as the scrolling arrows on your remote. It will take some practice, but to turn on the menu, press both volume buttons at once. Then practice using the volume controls to scroll. Once you have the hang of it, you can simply use these four buttons the same way you would have used your remote. If you cannot figure it out on your own, come back here, let me know, and I will sit down and map it out completely for you.
Hope this helps in some small way!
Sound bar only goes to #5 (low sound)
It maybe a model that is used in hotels and has a volume lock on it.You need to contact the manufacturer, or read the instructions on how to override it.
Philips TP2784C TV
You may try unplugging the set for about 10 seconds and trying again to see if it resets itself. If that doesn't work, you could be lucky and just have a blown fuse inside the set. Do not put in a higher amperage fuse than what it calls for though, and if the new one blows don't try another. IF the fuses are good, then you probably have a problem in the power supply and if the set is less than 6 years old, it may be worth repairing.
