I suspect you are asking about the convergence or brightness. See below for both common problems and fixesBelow are two of the most common problems encountered with projection TV sets.
Problem #1 - CONVERGENCE PROBLEMProjection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. This is a very common failure on Projection TV sets and a fairly simple DIY fix.
Common Symptoms include....- Screen looks 3D
- Colors don't line up
- One or more colors can't be adjusted when using the convergence menu.
- Screen is bowed or warped.
- TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....Using your original remote go-to the settings menu then goto the convergence section.Try to adjust the red and then the blue convergence.You should be able to move RED and BLUE in all directions - up, down, left, and right.If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem. Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
CONVERGENCE SOLUTIONYou will need to replace the convergence chips and possibly some convergence resistors and pico fuses. This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from
TvRepairKits.comTheir kits include a step by step instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Problem #2 CRT Fluid is CloudyProjection tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around video. Pic of a set that needs the fluid changed. Notice how dull the colors are and how white the screen looks. The screen may also look red, orange, dull, etc.
BEFORESet after fluid change. Notice how bright the colors are now. Everthing looks crisp and sharp again.
AFTERSolution #2 - CRT FLUID FIXWhat you will need to do is replace the coolant and clean the crt. You can get a repair kit from
TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
