20 Most Recent
LG BX580 Blu-ray 3D Player Questions & Answers
My 3D blu ray does
Hi you may need to update the firmware of the DVD player. If that don't work it may be the DVD player itself.
http://www.lg.com/uk/support/product/support-product-profile.jsp?customerModelCode=BX580&initialTab=documents&targetPage=support-product-profile
How to unlock region code for LG BX580
Greetings key5151 - Unfortunately there are no region code hacks or fixes for this player.
You might want to occasionally check in at videohelp.com
HERE. It is unlikely that anything will turn up as LG has locked down this unit tight.
Regards,
Mikeywaf
I have a LG dvd
player 5083 inserted the disc the correct way into the draw but the machine does not play the disc a very slight humming noise is heard then it spits the drawer back out
Clean the Lens: Use a DVD cleaning disc to clean the lens. If the problem persists, consider professional cleaning.
Test Other Discs: Try playing different DVDs to see if the issue occurs consistently. If it's specific to one disc, that disc might be the problem.
Check for Updates: Make sure your DVD player's firmware is updated. Refer to the manufacturer's instructions for firmware updates.
Try a Different TV: Connect your DVD player to a different TV to see if the noise disappears. If it does, the issue might be with your TV.
The hum is simply the player trying to read the disc. It can't so, it spits it out.
Remember that prolonged use of a malfunctioning DVD player could potentially cause damage. If the problem persists, consider seeking professional repair or replacement
