20 Most Recent
Fujitsu P42VHA30WS Television Questions & Answers
I have recently moved into
1. Yes, it has 2 speakers with 2 x 10 watts power. Check the link below for the specs:
http://www4.shopping.com/xPF-Fujitsu-P42VHA30WS
2. I couldn't find a way to access the menu without a remote
3. Try these codes and it might work for your universal remote control:
007, 008, 009, 021, 026, 028, 029, 032, 033, 040, 041.
Hope one of these codes work with your remote control.
3/27/2019 12:34:53 AM •
Fujitsu...
Answered
on Mar 27, 2019
I need a remote control
Hello
Universal remote codes for Fujitsu with RCA RCR311S universal remote control are:
1228, 1027, 1186, 1229, 1045
OK.
7/2/2011 10:42:51 AM •
Fujitsu...
Answered
on Jul 02, 2011
I direct tv picture but no sound
When troubleshooting these units, there are always several variables to consider. First check to see what last occurred with the unit such as did the children play video games, did the electricity go out due to bad weather. You may see that there are many possibilities but let's focus on what occurred last to the unit. Once we determine what happened last, we may isolate the actual cause of the problem. The actual cause may be associated with projection issues, older versions (Picture tube), interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common with the error you have provided today. Please continue to look for anything EXTERNAL to the unit before looking at the internal components. I have been working on these a long time so feel free to follow up with me. If your connected to a seperate speaker system, attempt to disconnect from that unit and only run sound through your tv to see if that does the trick.
1/16/2011 2:00:35 AM •
Fujitsu...
Answered
on Jan 16, 2011
Get an error message
Condition 1 error denotes there is some defect in the fan inside.
You cannot deal with this problem.
Please remove the plug from receptacle and contact you dealer
Thanx
7/31/2010 7:59:51 AM •
Fujitsu...
Answered
on Jul 31, 2010
Picture gets hung
Resetting the TV
If the buttons on the
remote AND the buttons on the TV case do not work (channels do not
change and you cannot open or navigate the menu), the TV has stopped
responding. Reset the TV as follows:NOTE: Some
TVs have a reset button. If available and accessible, try using the
reset buttons before using the steps below. Using the reset buttons can
save time. 1. Unplug the TV power cord from the power outlet.2. Unplug any connected devices (DVD, Set-top boxes, etc...)3. Press and hold the TV power button for five seconds.4. Plug the TV power cord back into the power outlet and turn on the TV.5. Open the on-screen menu to confirm that the TV is responding again.6. Turn off the TV and reconnect the devices.7. Turn on the TV.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
8/17/2008 7:49:20 AM •
Fujitsu...
Answered
on Aug 17, 2008
