20 Most Recent RCA 20F530T 20" TV Questions & Answers
Parental control lock
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. http://electronicshelponline.blogspot.com/ Pull up older posts there.
3/28/2014 5:42:58 AM • RCA 20F530T 20"... • Answered on Mar 28, 2014
TV was working fine, I have dish network and this
There are a lot of different possible issues that may cause this most likely the TV is on the wrong station. Try tuning it to 60 or 73 if this doesn't resolve the issue just reply!
Daniel Busa
DISH Network
Customer Service
6/3/2011 4:53:51 AM • RCA 20F530T 20"... • Answered on Jun 03, 2011
Have new sony dvd player
Hello prunefeet.
If you're certain you've connected the cables correctly, I think the part you may be missing is selecting the correct input on the TV. Switch the TV and DVD player on, then press the INPUT button on the RCA remote (supplied with the TV) slowly and repeatedly until you either get the setup/welcome screen from the Sony DVD player or you return to the TV channels again.
If you don't have the original RCA remote control or you cannot find the signal from the DVD player by pressing the INPUT button, please can you let me know the following:
1. How many jacks/plugs are there on each end of your RCA cables - 3 or 5?
2. Which remote control do you use to operate the TV?
Thanks,
BElectric
3/27/2011 8:36:31 PM • RCA 20F530T 20"... • Answered on Mar 27, 2011
The frontpanle on my rca
Front Panel Lock
Selecting this option lets you lock (disable) or unlock (enable) the TV's front panel. The remote still tunes to any channel. When using this as a Parental Control method, remove access to any remote
that is capable of operating the television.
1. From the PARENTAL CONTROL menu, press the up or down arrow to highlight Lock Fr. Panel.
2. Press the right or left arrow to turn on (box has check mark) or off (box doesn't have check mark) front panel lock.
9/22/2010 3:00:16 PM • RCA 20F530T 20"... • Answered on Sep 22, 2010
TV has a greenish tint
first off are there any speakers close to the tv ?. if so move them secondly your degauss circuit may need servicing.
4/30/2009 7:01:10 PM • RCA 20F530T 20"... • Answered on Apr 30, 2009
RCA Tv acting wierd
Must be leaky processor
12/3/2008 5:19:45 PM • RCA 20F530T 20"... • Answered on Dec 03, 2008
Picture TV screen is all Tint on my TV
FACTORY RESET
11/9/2008 12:03:02 AM • RCA 20F530T 20"... • Answered on Nov 09, 2008
COLOR
If, when you turn down the color control all the way you have a black and red picture, then your picture tube is most likely weak and it's time to replace the set. If the black and white picture is normal, then the set could have a problem in the chroma circuit. Either way, it would not likely be worth repairing.
9/25/2008 6:42:03 PM • RCA 20F530T 20"... • Answered on Sep 25, 2008
RCA 20" TruFlat picture is yellow
on the kine board,( the small board plugged on the back of the tube.) look for and test rb030,rb050,rb070, all 3 resistors sould read 1000 ohm (or 1k ohm). I suspect one of there resistors are open. if not on ib001 (same board). you can check for these voltages. pin1 2.8v, pin2 2.9v, pin3 2.9v, pin4 0v (ground), pin55.9v, pin6 181v, pin7 104v, pin8 105v, pin9 111v. all voltages are in dc. hope this helps.
8/29/2008 9:28:16 PM • RCA 20F530T 20"... • Answered on Aug 29, 2008
Screen on rca tv compressed into 2 inch line in middle
The 20F530T uses the relatively newer ITC008 chassis. If the picture collapses down and only a small bright line is visible, it means that your vertical output IC has stopped working correctly. This could be due to a defective IC, cracked solder joints on the IC or the power supply that feeds it. The IC should be replaced or resoldered and/or the vertical power supply restored by an experienced tech familiar with the new line of RCA TV's.
8/11/2007 5:28:47 AM • RCA 20F530T 20"... • Answered on Aug 11, 2007
2answers
Powers up but shuts down when play button is pressed RCA YLG43E
Try to check the power supply output side where anything could came into contact with positive and negative line for which when you press play button then it shuts down.
3/25/2024 6:44:15 PM • RCA Televison &... • Answered on Mar 25, 2024
Black and white screen only on DSTV?
RCA video cables handle analog signals. HDMI cables carry digital video signals. You need a converter. If you are using a component video converter, check if you swapped two of the three RCA video cables. (There are some A/V projectors that can do the translation of RCA and HDMI internally. Most TVs do not.) I hope this helps. Cindy Wells (One of my family's TVs used a dongle to condense the analog video signal to a single port, swapping blue and green gave a black and white output, IIRC.)
3/24/2024 11:03:58 PM • RCA Televison &... • Answered on Mar 24, 2024
I have an RCA re20qp80 remote that the mute button doesn't work
Most modern tv remotes are not normally designed to be repaired. You will possibly need to replace it. there are plenty of cheaper after market version that will do the job just as well. Your other option, and yes I know this is a silly answer, when you want to mute the TV is to simply press the volume down button to zero then turn it back up when you want sound.
2/23/2024 10:21:26 AM • RCA Televison &... • Answered on Feb 23, 2024
2answers
How to connect rca vr667hf to tv
you will need to rind RCA to whatever input is on your tv google RCA to HDMI copy and paste link for manual https://www.manualslib.com/manual/313476/Rca-Vr677hf.html#manual
2/18/2024 4:51:27 PM • RCA Televison &... • Answered on Feb 18, 2024
2answers
I Want code list for RCA 4- device universal remote
You need the TV codes not the remote ones. I would use the Remotes code search feature as the Sanyo has allot of codes and you may spend hours going through them. Sanyo remote codes 0154 0208 0157 0280 0484 0292 0721 0011 0036 0045 0370 0068 0339 0072 0216 0104 0217 0145 0146 0156 0555 0381 0412 0009 0508 0544 0163 0799 0037 1154 0108 0159 0556 0486
2/2/2024 11:35:38 PM • RCA Televison &... • Answered on Feb 02, 2024
Where is the fuse located on a rca flat screen tv
The fuse on an RCA flat screen TV is typically located on the power supply board near one of its corners. The power supply board is the board with an array of capacitors, resistors, and heat sinks on it . The fuse is a small cylindrical tube with metal caps and is relatively small compared to other components on the board . If you have never seen a circuit board before, finding the fuse may be tricky. You can consult the user manual for your TV if you need help locating the fuse . TV Fuse Replacement Guide: Locating and Replacing Your TV Fuse - PointerClicker.com Replacing the fuse should be done with caution, especially if it is soldered to the board, as errors could lead to costly damage. You can check if the fuse is blown visually or with a multimeter-like tool. If you are unsure about how to replace the fuse, it is best to seek professional help.
1/21/2024 8:13:40 PM • RCA Televison &... • Answered on Jan 21, 2024
What is the code for remote control for RCA model# RT 1971-AC
Better idea https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
Replacement Remote Control for RCA DETG160R ...
Amazon.com https://www.amazon.com > Replacement-DETG160R-... Replacement Remote Control for RCA DETG160R DETG190R RT1971-AC RLDED3932ARK LCD LED HDTV TV - ( Compatible Model: DETG160R ) ; Controller Type. Button Control. US$32.99 · ‎In stock
RCA RT1971AC Replacement Remote
Remotes.net https://www.remotes.net > products > replacement-rem... If your original RCA remote has died, been destroyed or lost, or has simply stopped working, this replacement RCA remote can be the solution to your problems. US$34.90 RCA Universal Remote Codes:
  • The TV codes are: 000, 006, 011, 019, 027, 034, 038 and 044.
  • The VCR codes are: 000, 005, 007, 008, 028 035, 037, 054 and 069.
  • The cable box codes are: 000 and 027.
Apr 26, 2023
RCA Universal Remote Codes List 4 Digit - GenTwenty
12/27/2023 12:47:10 AM • RCA Televison &... • Answered on Dec 27, 2023
Rca remote r26211 code for trutech tv dvd
Better to get a Facsimile Remote, a copy made for the unit. It is unlikely, you can input codes to work both applications in a combined set.
TruTech TV universal remote control codes (3, 4 and 5 digit)
eliztech.com https://www.eliztech.com > remotes > codelists > trutec... Universal remote codes for TruTech TV sets - 3 digit, 4 digit and 5 digit codes.
My mom has a Trutech combination TV/DVD, about 20 ...
JustAnswer http://www.justanswer.com > TV Problems Feb 6, 2013 - There are very few universal remotes that will operate a tv/dvd combo and of ten if you find a code then the tv a dvd have separate codes. 1 answer · Top answer: Jack : Hi and welcome to justanswer. To answer your question; There are Make sure you use the FULL Model Number for it.
TRUTECH TV Replacement Remote
Remotes.com https://www.remotes.com > trutech-remote-controls-s Replace new & discontinued remote controls for TRUTECH devices with fully programmed remotes from our online store. Enjoy low prices and fast shipping.
Trutech Remote for sale
eBay https://www.ebay.com > ... > Remote Controls Sort ; 2PCS Remote Control For TruTech KLV3170 LCD Drop Down TV Built-in DVD Player · $13.83 ; TruTech A60P0315 Remote Control Genuine OEM TESTED · $3.00 ; Original ...
Trutech Remote Control
Amazon https://www.amazon.com > trutech-remote-control > k... GE Universal Remote Control for Samsung, Vizio, LG, Sony, Sharp, Roku, Apple TV, TCL, Panasonic, Smart TVs, Streaming Players, Blu-ray, DVD, 4-Device, ...
12/20/2023 1:17:20 AM • RCA Televison &... • Answered on Dec 20, 2023
I dropped my RCA remote control, how can I reestablish connection with Magnovox tv?
Check that the batteries haven't become disconnected. Do the Smartphone camera test to see if it is transmitting a signal. If it isn't, buy a remotes specially made for the Magnavox rather than an RCA Universal. Google Magnavox (model) remote control replacement. https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote ..
11/30/2023 4:26:09 PM • RCA Televison &... • Answered on Nov 30, 2023
RCA 20F530T 20" TV Logo
17 questions posted
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Televison & Video
Most Popular Question
new sony dvd player
  • Televison & Video
