20 Most Recent
RCA VCA115 VHS-C Adapter Questions & Answers
Hi8 insert tape
I don't believe there are hi-8 adapters, only VHS-C to standard VHS... are you looking for a hi-8 player?
How to remove a tape from the adapter? (I just
Use the manual wind beneath the adapter to wind off the VHS-C into the shell. If this is the motorised type also there is provision to wheel inthe tape manually. Once it goes back in the tape will eject up by itself with the wheel turned
If not remove the screws of the adapter-5-6 screws and open to release.
Doesn't seem to have a battery in the adapter -
You must first put on the battery so that the mtor reurns back to the return mode so that the VHS-C can be placed . Once the door is shut after placing the cassette, the tape is wound up and it becomes just like a regular VHS tape. Now if this is not happening there is always a small gear on the back side with which you can manually wind to bring it up to the desired level. If not the motr is stuck or the pulley is running loose. You can open up and check inside , it is a simple mechansim with a switch to activate and return. Check the motor and gears. reset the drive by removing, check the battery voltage to the motor and your adapter will work. hope you check this out. Good day
Trying to remove video cassette from vca115
Not sure what type of problem you have with this adapter.
You have to move the slide switch on the top cover slightly right to ease the spring that holds flip door. The door swings open and you can take out the C-VHS tape.
I hope the battery is there. But that is required only if your are loading a tape in.
Hope this solves the problem, if not please post a comment with details on how far are you with opening the door.
