20 Most Recent
Samsung PS42P2S 42 in. Plasma Television Questions & Answers
Samsung 50" plasma won't turn on
Same problem.damn inferior product.I knew I shouldve stick with sony.Ive had mine for 7 months and according to the guy I bought it from hes had it almost a year.No power
Pc appears on screen and then no plasma input after about 1/2 hour
hidefhfhfieiikkfjjfkjfjgjhhfkdfeoighorwGHFD;OAHJLIEjhoierjhfbiufhlkvmnkfdljhbfiolksfhlksfjhflkdjfiglkhrfighflkjhgfjlkghifdhglkrjfkjgkgofjhopfjhoiigjpoehoierjoigehoierhpehirgerojhierhpoejhoruhieruoerpigoruhjpoerugrhureopgrepueophepupojrpoepupogririerpouheuhpoerporugporuorhurpoioerupoeueropupopoerpoerupoererupoepopoeugjrgrijgrijpjpperjjgerjrejuregjrrgihrggrgjjjjjfjfigoiriiririijjfifjjjifiihirguhguihgoijgoihfsgsjoighsfigohsoighskgjkfslghlkshskghs
How to replace bulb in 32 inch Curtis flat screen?
Replacing procedure of bulb to projection TVs, are almost the same irrespective of Brand.
If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic
/ Time slide, can be selected by the drop-down list, at the top left
of the display window, will make surf easy. You can also do a search, by type in the brand name/model
number/IC used, in the search box at the top right of the display window.
We have lost a two inch wide black section on the
Most likely the lower buffer board " E " needs to be replaced. Right now I'm working on repairing a 42" Samsung plasma HP-R4272. The Service manual for that TV says for trouble shooting for that problem is the lower buffer board " E ".
Best to find the correct Service Manual for your TV over the internet to get the correct part number for replacement. The Service Manual should be less than $20.
Samsung blue lines
I will presume it is a Plasma as indicated here----lines top/bottom or left right are not easy to fix as far as knowing what to replace.Set has a main board that communicates with the screen and directs information there--can be in one of three general areas:1. Main Signal board (most likely)2. Power supply as voltages are critical (less likely)3. Display panel (the screen unit itself with a defect inside it) the last is least likely but possible.
