20 Most Recent Samsung HP-R4252 42 in. Plasma HDTV Questions & Answers
3answers
When i plug in xbox to hdmi input it reads
The X-Box will not work on the HDMI input on that model. Either use the Component input or the Composit input.
11/23/2020 4:44:46 PM • Samsung HP-R4252... • Answered on Nov 23, 2020
I have a samsung HP-R4252 42
REPLACED Y BUFFER BOARD
Samsung BN96-02034A BOARD, Y BUFFER UPPER ASSY
Samsung BN96-02216A BOARD, Y LOWER BUFFER ASSY LJ92-01203A
10/17/2019 1:59:01 AM • Samsung HP-R4252... • Answered on Oct 17, 2019
Samsung Plasma HP4252 type SR42P5 verticle blue lines across entire screen
First off there isn't a timing board in a plasma TV. I would guess you have a bad y-sus board.
2/20/2018 2:18:24 PM • Samsung HP-R4252... • Answered on Feb 20, 2018
2answers
Samsung plasma 42" model HPR4252xlxaa only have picture in center of screne the rest is black or black mesh. sometimes the whole screne brightens up for 15 to 30 seconds with great picture then goes b
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. https://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
2/2/2018 4:00:03 AM • Samsung HP-R4252... • Answered on Feb 02, 2018
0answers
Panasonic Viera THX 42 600W Plasma. I have two horizontal lines
Was there any physical damage? It is running of another device. Try using another input and see if the problem is still there. Sometimes plasma tvs have burn in.
11/2/2017 1:15:39 AM • Samsung HP-R4252... • Answered on Nov 02, 2017
Flickering Pixels on Plasma
The top y drive cable is loose or dirty. Delicate job to fix.
6/21/2017 1:25:21 AM • Samsung HP-R4252... • Answered on Jun 21, 2017
My samsung tv is stuck on standby mode and will not switch on can the standby be bypassed
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electro-medical.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
7/12/2016 4:36:06 PM • Samsung HP-R4252... • Answered on Jul 12, 2016
How do i repair no picture?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/. Some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
7/25/2015 3:13:02 AM • Samsung HP-R4252... • Answered on Jul 25, 2015
I want to samsung tv stand
If you are looking for a particular stand. You can often contact Rescued Parts for a OEM Stand even if you do not see one in stock they can look in the back and see what they have for you. RescuedParts com LED Plasma and LCD TV Parts OEM TV Stands and OEM TV...
1/20/2015 1:29:52 AM • Samsung HP-R4252... • Answered on Jan 20, 2015
Tv turns off after say 2 minutes , clicking sound can be heard at back of tv blue power light still on though
The capacitors on the power supply need to be replaced. When you take apart the TV, and then remove the power supply (it's the section that the power cord goes to) and open it up. Look for the little can capacitors and see if any of them are bulging on top. That is the sign that they've blown. Replace the big ones (about 5) for about $5 in parts. Reassemble and test by turning it on. Search for YouTube video on how to replace capacitors....
11/25/2014 9:22:22 PM • Samsung HP-R4252... • Answered on Nov 25, 2014
Horizontal lines on my samsung HP
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
9/1/2014 3:33:39 AM • Samsung HP-R4252... • Answered on Sep 01, 2014
TV IS NOT RECEIVING SIGNAL FROM LAPTOP
Check graphic card software on laptop to make sure it's on the right settings to output image to TV.
5/7/2014 3:03:43 AM • Samsung HP-R4252... • Answered on May 07, 2014
Samsung HP-R4252 42 in. Plasma HDTV Logo
281 questions posted
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
View Most Popular
  • Samsung Televison & Video
Most Popular Question
samsung hp r4252 42
  • Televison & Video
