20 Most Recent
Samsung HCP4252W 42" Rear Projection HDTV-Ready Television Questions & Answers
SCREEN
Yes, the screen can be replaced. The screen is comprised of 3 screens. The Fresnal Screen (inner screen), Lenticular Screen (middle screen), and the Protective Screen (outer screen). Please see below for links to these items.
Replacement Screen (need all 3 to complete screen assembly)
- Fresnal Screen
- Lenticular Screen
- Protective Screen
Red tint in dlp picture
A red tint in a DLP usually means a issue with the optical light engine it uses. A faint chance if a high pitched whine or fan like sound is the color wheel.......
How to reset eeprom(service menu settings)
This is the reason I am careful about walking people into the tech menu on sets--one wrong move and poof!If you by a miracle find the full service manual it would have the information needed (if set has this) for a hard reset---other wise you would have to try to with the manual reset every setting to factory one at a time...........
Samsung rear projector tv Model SP42Q2HL HDTV
No,is it not.It a repairable tv.The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all it resistors too.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
I have a Samsung HCP4252W
This may simply be a focus problem or something to do with the convergence setup.
To perform any service work on these sophisticated devices, at least, one needs a Service Manual, for their exact make and model, this gives one the test and setup, and troubleshooting procedures and also the parts numbers required.
It can be extremely difficult to track down problematic part, even for an expert, however if one can track down the fault to a
board, then replacement isn't that hard.
http://servicemanuals.vstore.ca/product_info.php/pName/hcp4252w-service-manual-cd
Above is a link for a service manual.
I have a samsung hcp4752w
Have You Replaced Convergence ICs,If not replace Both of them and 2 resistors 2.7ohms 1watt ICs are STK ICs big Black IC will have part number on them STK392-020. Mats Electronics has them in stock
1-800-628-1118
Projection is off and blurry
change theconvergence amplifiers STK 392-040 also check all resistors in the convergence circut if you want to test it first press MUTE 183 on the remote "DO NOT PRESS ANY ADJUSTMENTS AS YOU WLL TOTALLY SCREW UP THE PICTURE THIS IS ONLY SO YOU CAN SEE WHAT THECONVERGENCE IS LIKE"
Samsung 55 TV White vertical patches?
It sounds like you might be dealing with backlight bleeding or an issue with the LED backlighting in your TV. This can sometimes occur over time due to normal wear and tear or manufacturing defects. If it started as a faint single brighter section and has now expanded to four, it's likely a hardware issue. While it may not be an easy fix, contacting the manufacturer's customer support or a professional technician would be a good next step to diagnose and possibly repair the problem. If you'd like, you can share the pictures for a more accurate assessment.
4/14/2024 7:29:30 PM •
Samsung...
Answered
on Apr 14, 2024
