20 Most Recent
Android LG Optimus Dynamic II LG39C Smartphone fo Questions & Answers
How do I get into my lg phone when I forgot my pin/password
The only way to get back into your device is to do a factory reset. Keep in mind, Google has an activation lock to prevent theft of your device. With that being said, after you factory reset your phone it may ask you to login to the original gmail account that your device was set up with.
To do a factory reset, you need to boot the phone into recovery mode:
- Power down the device
- Hold down the following keys:
Volume Up + Home + Power
or
Volume Up + Home + Search
I’m happy to assist further over the phone at
https://www.6ya.com/expert/christopher_d13aca62d29ed9ae
Screen goes black after making call which means I can't punch in extension
Sounds like the proximity sensor. The phone has a sensor that attempts to determine if the phone is up to your ear, and then shuts the screen when it is to save battery. However, if you have a screen protector of any sort it can block the sensor, making the phone think it is up to your ear once you place the call.
Easiest way to test this is to disable the proximity sensor then place a call. If the screen does not instantly go black after you place the call, then you know for sure something is blocking it. If you have a screen protector, try removing that.
To disable the sensor:
- Goto settings
- Call settings
- Additional settings
- Uncheck the proximity sensor box
TRIED TO ANSWER TEXT, GOT BACK INSUFFIENT FUNDS
you already got the problem there. Insufficient funds. that means you doesn't have enough balance to send text message. But if you sure you have enough then contact your network provider and complain to them because it will be their error not the phone
Will my LG Optimus call 911
Yes you can call 911 with this phone (andriod optimus dynamic 2 LG36C smartphone. You can either go to the unlock screen and click emergency call or you could go to the dialing screen and dial 911. I Hope this was help to you!!
Transferring memory from phone memory to installed sd card
you can not transfer the apps that are installed as they have been installed into the phones memory ? you can download the full app onto the card then install onto the phone. ( when an app is installed into the phone it needs "bits" of the phones software to run so its "sort of " all in small parts scattered all over the phones memory ) a downloaded app is a complete all in one program,it only gets sent all over when installed... only way to save room is to "uninstall" some apps
How to get out of emergency call, frozen and no icons or menus
try a reboot or restore both options are in the following menu. turn off phone. press and hold the volume up button and the home button ( on the front ) now with a spare finger turn the power on ( keep holding the 2 buttons ) you should see the green android then a menu. if you dont see it then turn off and try again. only leave go of the buttons when you see the little green android man
I need to know, how do you use speed dial ?
you can use speed dial to call some selected numbers you personally choose to call. it is fast to call the phone number just by long pressing a key from you keyboard.. Moreover, you can use keys from 2-9 one your keypad but 1, is reserved for voice number.
Keep getting "message expired"
Some providers and or phones have a time limit on the pics sent via txt or mms. Unfortunately idk if you can recover your past pics. But the next time you recieve a pic this way, try tapping and holding the image to bring up the options menu. Then select save image or download image. This will save the image to your gallery.
