20 Most Recent
LG Electronics - DP132 Multi-Format DVD Player with USB Plus, JPG Playback, MP3 and DivX, Dolby Digital Support, Parental Lock Questions & Answers
Need a regional unlock code for LG DP132 please ...
Power ON with NO disc inside:
Press PAUSE on the remote-control
Press 3,1,4,1,5,9 in sequence using the remote-control
Press 0 on the remote to select Region Free
Press PAUSE again to save
Power OFF then Power ON.
Done.
Dvd dolby
generally auto plays without remote
if there is interactive menu then its a problem.
get another remote
How do I get a signal?
The only thing between the player and the TV is the cable. Make sure it isn't the problem by trying a different cable or a different input on the TV.
I have a LG dvd
player 5083 inserted the disc the correct way into the draw but the machine does not play the disc a very slight humming noise is heard then it spits the drawer back out
Clean the Lens: Use a DVD cleaning disc to clean the lens. If the problem persists, consider professional cleaning.
Test Other Discs: Try playing different DVDs to see if the issue occurs consistently. If it's specific to one disc, that disc might be the problem.
Check for Updates: Make sure your DVD player's firmware is updated. Refer to the manufacturer's instructions for firmware updates.
Try a Different TV: Connect your DVD player to a different TV to see if the noise disappears. If it does, the issue might be with your TV.
The hum is simply the player trying to read the disc. It can't so, it spits it out.
Remember that prolonged use of a malfunctioning DVD player could potentially cause damage. If the problem persists, consider seeking professional repair or replacement
