20 Most Recent
Philips HTB3510 5.1 3D Home Theater System - 1000 W RMS - Blu-ray Disc Player - Black Dolby TrueHD, DTS HD, DTS-HD Master Audio Essential, Dolby Digital Plus, Dolby Digital, DTS - BD-RE, DVDRW, DVD-RW, CD-RW - BD Video, DVD Video, DivX Plus HD, DivX, MKV Questions & Answers
How to unlock regional code of philips HTB3510 3d blueray player?
Check current region codeOpen the Philips HOME ScreenType on your remote: 8520This will display all of the current settings for your player. Example: Region_Code: DVD(2) BD(B)Change region codeTurn on player with no disk insertedPress "Open/Close" on the remote control until the tray is openPress 8689310 - 0 means all regionPress 8689311 - 1 means region 1, Press 8689312 - 2 means region 2, Press 8689313 - 3 means region 3, Press 8689314 - 4 means region 4, Press 8689315 - 5 means region 5, Press 8689316 - 6 means region 6.Now the front Buttons might not work!Go to SETUP and click on RESET FACTORY SETTINGSWait until the player restarts and now you can play all DVD regions
I have Philips TV mode
I'm assuming that you have checked that the sound is not muted. To confirm that a reset to factory settings is the next procedure: Menu - Setup - General - Factory settings. If you don't see/hear any modifications then it's a hardware defect, not something with the settings.
This happens when the tv thinks that the headphones are used. Simple test to confirm that: plug in a pair of speakers and see if you get the sound on them. If you get and the situation doesn't changes when you unplug them then this is a mechanical defect: the small switch inside the headphone jack is faulty and keeps signaling that the headphones are plugged in when they are not.
The only way to fix that is to replace the jack, which involves a very delicate soldering procedure , one that only a good repairman can do - you must call one.
12/13/2023 4:44:25 PM •
Philips...
Answered
on Dec 13, 2023
Philips DVP3150V/37 DVD VHS combo Player. I am Looking for a universal control for Philips DVP3150V/37. Which one will work.
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
How many would you like?
Genuine PHILIPS NA725UD DVD VCR COMBO Remote ...
eBay
https://www.ebay.ca > ... > Remote Controls
Genuine PHILIPS NA725UD DVD VCR COMBO Remote DVP3150V/37 ; Quantity. 4 sold. 8 available ; Item Number. 143886913897 ; Compatible Brand. For Philips ; Accurate ...
$67.67 · In stock
PHILIPS 996500027557 DVP3150V37, DVP3150V, ...
eBay
PHILIPS 996500027557 DVP3150V37, DVP3150V, DVP3150 REMOTE CONTROL ; Model. DVP3150V ; Type. Remote Control ; Accurate description. 5.0 ; Reasonable shipping cost.
US$59.95
Buy PHILIPS NA725UD -996500027557 DVD/VCR Combo ...
ReplacementRemotes.com
https://www.replacementremotes.com > philips > buy-...
PHILIPS NA725UD-996500027557 dvd/vcr remote control for DVP3050V, DVP3050V/37, DVP3050V/37B, DVP3050V37, DVP3050V37/VCR, DVP3050V37B, DVP3150V, DVP3150V/37
12/5/2023 4:44:13 AM •
Philips...
Answered
on Dec 05, 2023
My rmt-d197a remote, i am trying to pair with my Philips t v
In order to pair your RMT-D197A remote to your Philips TV, follow these steps: 1. Power on the TV with the remote. 2. Press and hold the Setup button on the remote until the red LED light blinks twice. 3. Input the four-digit code that corresponds to your brand of TV on the remote. This should be found on the enclosed code list. 4. Release the Setup button. If the code is correct, the red LED light will blink twice. 5. Aim the remote at the TV and press the Volume Up button. If the TV responds, the remote is paired correctly.
10/31/2023 4:44:00 PM •
Philips...
Answered
on Oct 31, 2023
Philips tv Model - 21PT3525/V7 I want EHT Number ?
The EHT number for a Philips TV model 21PT3525/V7 can vary depending on the specific version of the TV. However, the EHT number for this model is typically BSC25-0235 or BSC25-0217.
It's important to note that replacing the EHT can be a dangerous process, as it involves working with high voltage components. If you're not experienced with electronics repair, it's recommended to seek assistance from a qualified technician who can perform the repair safely and properly.
3/4/2023 1:03:43 AM •
Philips...
Answered
on Mar 04, 2023
How do I program my Magnavox universal remote to my Philips Magnavox fw530c mini Hi-Fi stereo
To program your Magnavox universal remote to your Philips Magnavox FW530C mini Hi-Fi stereo, follow these steps:
- Turn on your Philips Magnavox FW530C mini Hi-Fi stereo manually.
- Press and hold the "Code Search" button on your Magnavox remote until the indicator light turns on.
- Press the "Device" button on the remote, which should be the button corresponding to your stereo.
- Enter the 3-digit code for your stereo. You can find a list of codes for Philips Magnavox products in the user manual for your universal remote or online. If you do not have the manual or cannot find the code online, try entering codes 006, 007, 010, 011, 013, 016, 027, 033, 035, 043, 066, 087, 089, 114, 117, 118, 119, 120, or 123.
- Press the "Power" button on the remote to see if the stereo turns off. If it does, you have successfully programmed the remote. If it does not, repeat steps 2-4 with a different code until you find one that works.
- Once you have programmed the remote to control your stereo, test out the other buttons to make sure they work as well (such as volume control, track skip, etc.).
Note: If you cannot find a code that works for your stereo, you can also try the "Code Search" function on the remote. This may take some time, but it will automatically search for the correct code until it finds one that works.
2/26/2023 6:54:07 AM •
Philips...
Answered
on Feb 26, 2023
