Go into settings go to notification go down to messaging and then go down to email look to see that notification is turn on in messaging and then go to email & c F notification is on in email
Scott, To transfer your number from your Old Service Provider to TracFone Wireless, you must ask TracFone to Port your existing telephone number. TracFone Wireless will process the request for you. During this process, your service with your current provider will be disconnected automatically and Activated with the new provider you have selected. There is no need for you to call your current provider to disconnect your service. During the Request process, you will still be able to place calls on your existing wireless telephone or wire line phone. You, however, will not be able to receive calls during the porting process.
Above information from link below, tracfone.com. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.tracfone.com/includes/content/questions/General.jsp?enId=FA10060&esId=FA10061&a=1396990859478http://www.tracfone.com/includes/content/questions/General.jsp?enId=FA10025&esId=FA10026&a=1379709875366https://www.tracfone.com/direct/init_activation.jsp?app=TRACFONE
Hi Michael. The link below is a short youtube video on how to rest the pattern code on your phone, The
guy shows 3 way but the 3rd way is a factory reset meaning you loose every thing in your phone
but the first two ways are worth watching. I hope this helps...... CHEERS..
EASY WAYS How To Unlock Android Passwords
most phones need a sim card to connect to a service provider and to store information like usage, phone number so that it can be called, unless the pay cards have a sim card included
if not then you will have to pay the service provider by debit card every 30 days or get disconnected.
most cards are under the battery
When you are on the letters virtual keyboard and want to enter a number or a symbol, tap on the box marked '123' or '123Sym'. That brings up the numbers+symbols virtual keyboard. After entering the number(s) or symbol(s), tap on the box marked 'ABC'. That will bring back the letters virtual keyboard.
depends on which carrier or phone company has there phone switch system set up. Each phone company and cell company determines there own caller id layout.
To add Bluetooth functionality to your LG FB163, you can use a Bluetooth adapter that is compatible with the device. Ensure that the adapter you choose is compatible with the FB163 model. Once you have the adapter, follow the instructions provided with it to connect it to your FB163 system.
To connect your Android phone to the FB163, you'll need a compatible cable. Typically, you would use an auxiliary (AUX) cable with a 3.5mm jack on both ends. Plug one end into the headphone jack of your Android phone and the other end into the AUX input port on the FB163 system. Then, select the AUX input mode on the FB163 to hear the audio from your phone through system.
