20 Most Recent Dragon Touch Touch R10 10.1 Google Android 4.1 Dual Core Tablet MID PC, Rockchip RK3066 Dual Core Cortex A9 CPU up to 1.6GHz, 1Gb RAM, 8Gb HDD, Multi-Touch Screen, Front Camera Rear Camera, Google Play Pre-Installed, HDMI Questions & Answers
How can i get a cracked screen repaired?
You can get it fixed buy going to ubreakifix.
10/20/2016 10:19:17 AM • Dragon Touch... • Answered on Oct 20, 2016
Get message printer spooler has stopped when i try to print
If printer spooler stopped when you try to print have you checked to see if anythings wrong with the printer. If so and nothing was wrong maybe your printer spooler is to full so it stopped working.
10/20/2016 10:13:22 AM • Dragon Touch... • Answered on Oct 20, 2016
Charger port is loose or broken and wont charge anymore how can i fix it?
You probably can fix it but your best bet is to buy a knew one.
10/20/2016 10:02:27 AM • Dragon Touch... • Answered on Oct 20, 2016
Wifi antenna is in the halway and when i enter my room SWOOSH WIFI IS GONE
There are multiple fixes for this...but the easiest is an extension antenna.
5/11/2016 8:15:12 PM • Dragon Touch... • Answered on May 11, 2016
It wont charge it feels like the port is loose. How can I fix?
The USB port socket feel out of my dragon
2/23/2016 9:10:49 PM • Dragon Touch... • Answered on Feb 23, 2016
Tab has frozen; can't turn on or off. Anyway to fix?
Hold your finger on the on/off button for about 15 to 20 seconds . That should shut down the tablet and reset it. I have had 3 tablets and everyone has reset from a frozen screen that way. Afterwards you should run your anti virus program and bolter to clean up what caused the traffic jam.
2/9/2016 8:22:10 PM • Dragon Touch... • Answered on Feb 09, 2016
I purchased my tablet from a pawn shop yesterday and don't know how to hard reset it due to there being a lock pattern on it and don't know the g mail account associated with it
1) Power down your tablet. 2) Tap the power-on button and volume down button at the same time 3) Tap and hold the power-on and volume down buttons until you see the android alien icon 4) tap the power-on and volume up again at the same time until you see the System recovery menu. Android System recovery menu Volume up/down to move highlight; power button to select. Options are below reboot system now apply update from /sdcard wipe data/factory reset wipe cache partition recovery system from backup update rk image from /sdcard select (wipe data/factory reset) bush pushing the power button to select it and restart the device after.
10/17/2015 11:01:32 PM • Dragon Touch... • Answered on Oct 17, 2015
What are all the connections for on the side of my dragon touch tablet?
download a manual, it will provide you with all the answers you require
10/11/2015 5:08:18 AM • Dragon Touch... • Answered on Oct 11, 2015
How do i clear downloads.
Your tabet should have some kind of a File Manager in the apps main menu. Open it and look for the Download folder which should appear when you open the internal SD icon. Open the Download folder and you should see your downloaded files. You have the option to select one or more of them and the selected ones you should have the option to delete. Use the three dots in the upper right on most file manages to choose delete, copy move etc. Be extra sure you're in the Download folder before you delete anything, though.
10/9/2015 3:32:50 PM • Dragon Touch... • Answered on Oct 09, 2015
Is battery removable? replaceable? available for purchase?
Yes you can either search one on the Internet, or I think Amazon has some you can choose from
9/7/2015 5:57:32 PM • Dragon Touch... • Answered on Sep 07, 2015
What do i do when my tablet says cannot open file
NOT ALL FILES CAN BE OPENED BY A TABLET. Each filetype is associated to some applcation which is used to open it for some particual purpose. If you don't have the application associated to a detemined file you can't open it. So, to help you, please tell us which are the files you couldn't open and maybe with a few word, what they are supposed to do
7/31/2015 10:20:42 PM • Dragon Touch... • Answered on Jul 31, 2015
0answers
Hi,When plugged into the mains, it's shows it is fully charged. It will also power up and function as per normal. When I disconnect from the mains it does not power up at all. What should I do?
Your rechargeable battery has simply gone dead. (They do not last forever.) Install a new battery, and you'll be good as new.
5/13/2015 5:44:50 PM • Dragon Touch... • Answered on May 13, 2015
I inerted a 32gb SD card and nothing happened so I popped it out anthem I could not get it to pop ck in tablet said new SD card???
When you insert an SD card in the slot the tablet will *mount* it automatically. This means it connects to it and formats it and adds some files and folders so it can utilize it. Before you remove it you need to go to Settings>Storage>External SD and touch the *unmount* option. If you don't do this there is a chance the card can be corrupted and can become unusable. If the tablet said new SD card then you might have to go into Settings>Storage>External SD and touch the *Mount* option. If it's a new SD card chances are you didn't hurt it. But if it's a use one on which you had a lot of data stored and you didn't unmount it before removing it you could have damaged the file structure and your only option to get it back would be to put it into a card reader on a laptop or desktop and reformat it.
4/26/2015 8:18:33 PM • Dragon Touch... • Answered on Apr 26, 2015
Dragon Touch Touch R10 10.1 Google Android 4.1 Dual Core Tablet MID PC, Rockchip RK3066 Dual Core Cortex A9 CPU up to 1.6GHz, 1Gb RAM, 8Gb HDD, Multi-Touch Screen, Front Camera Rear Camera, Google Play Pre-Installed, HDMI Logo
44 questions posted
Top Dragon Touch Tablets & eReaders Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Paul Bade
Are you a Dragon Touch Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
  • Dragon Touch Tablets & eReaders
Most Popular Question
barley hear dragon 10 1 even full volume
  • Tablets & eReaders
