20 Most Recent Toshiba 42H81 42" Rear Projection Television Questions & Answers
Power light blinking
I have a Toshiba 42H81 that has the power indicator light blinking and the TV will not turn on
8/10/2017 2:41:10 PM • Toshiba 42H81... • Answered on Aug 10, 2017
What is a universal remote code to a phillips
Please go to below website you can get the codes to programme out remote.
http://www.urc.philips.com/
Please follow the below instruction.
1.Location
2.Select your remote
3.On your left side you will have an option called as REMOTE CONTROL CODE FINDER.
9f4dce2.jpg 4.Select the device you need to programme and the make of the device you will get the codes.
Thanx
7/1/2016 5:15:39 PM • Toshiba 42H81... • Answered on Jul 01, 2016
What is wrong with th sound on my tv. Toshiba 42"
check the ff speaker,input/output amplifier , pre amplifier, audio signal from tuner or srs settings if possible
1/5/2015 1:26:21 PM • Toshiba 42H81... • Answered on Jan 05, 2015
Colored lines down the tv
old tv. don't put anymore money in it. get you a nice flat screen. not work it being a projection. jmo
10/8/2014 11:20:51 AM • Toshiba 42H81... • Answered on Oct 08, 2014
Toshiba 61 inch rear projection scrambled picture
If you are seeing lines and or noise for the first several minutes and it goes away--I think I know what the problem is.
Has the period of time before it clears up been getting longer and longer?
Reply to me with the exact model number and I will tell you what is wrong and what has to be done to fix it.
A lot of these sets have problems with what is called a HYPER board----it controls all signal inside the set--confirm Toshiba and exact model number---
I am here to help people and I do this here for free.
REGARDS, SD TECH
2/11/2014 1:07:39 AM • Toshiba 42H81... • Answered on Feb 11, 2014
Remote model CT-90086
Is it the correct rmote??Contact Toshiba Tech support. Call Shopjimmy .com
11/14/2013 7:41:09 AM • Toshiba 42H81... • Answered on Nov 14, 2013
Lock Button on Coby TV FlatScreen
try to see the manual of that tv or try to ask help of tecnicians thanksss and hope to help you
11/8/2013 12:54:35 PM • Toshiba 42H81... • Answered on Nov 08, 2013
Where to buy an IR sensor for my Toshiba #42H81
Hello, that is a Toshiba only item, you will have to contact them. tks
11/8/2013 4:48:17 AM • Toshiba 42H81... • Answered on Nov 08, 2013
How do I replace the IR sensor in my Toshiba
Hello, to replace the ir sensor, unplug the set, remove the speaker cover on the front, remove the screws around the plastic push button assembly, carefully remove the wire connections (plug connectors) off the assembly and remove the screws on the back side of the board and remove the board and replace it with the new assembly, re install the screws on the board, attach the wire connections and re mount the push button assembly and replace the speaker cover....tks
11/8/2013 4:45:04 AM • Toshiba 42H81... • Answered on Nov 08, 2013
Toshiba 42H81 42" Rear Projection Television Logo
507 questions posted
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Televison & Video
Most Popular Question
replace stk392 110 ic 39 s in toshiba
  • Televison & Video
