20 Most Recent
Panasonic KX-FL511 Plain Paper Laser Fax Questions & Answers
Kx-fl511 wont pick up paper
try cleaning the paper pick up rollers with rubbing alcohol, use a cloth rag and the alcohol, try to rotate the rollers so that you can clean all the way around
11/27/2020 1:04:44 PM •
Panasonic...
Answered
on Nov 27, 2020
Call Service 3
Press Menu first, then #9000*, next press 550, press Start, wait for printing, unplug the electric cord, wait 10s or more, plug it again, it's done.
11/26/2019 6:52:33 AM •
Panasonic...
Answered
on Nov 26, 2019
Document jammed
It sounds as through the paper jam sensor is either dusty so needs a clean, or the sensor has stopped working totally & needs replacing, if this item is still under warrentee I would call the company for the repair, if not a local computer repair company will be able to assist you further, most offer a free quotation service if you ask...
I do hope this helps resolve your problem, if you could reply & let me know the outcome, many thanks...
2/22/2018 9:06:32 AM •
Panasonic...
Answered
on Feb 22, 2018
Panasonic FX KPC 141
Call 1800-211-7262 for Panasonic's capable Technical Support; be sure to have the serial number of the product ready.
3/5/2015 10:51:25 PM •
Panasonic...
Answered
on Mar 05, 2015
Panasonic KX-FL402 change drum arror
Apparently the drum needs to changed, a clip is broken, the sensor is being blocked by debris from the cartridge or pieces of paper, a sensor fault or the unit needs to be reset.
3/5/2015 10:50:30 PM •
Panasonic...
Answered
on Mar 05, 2015
How do I delete stored faxes in a Panasonic KX-FL511 without printing them?
The manual indicates where you may need to reset the unit if the memory is full or even if you just want to clear it, page 89-90.
You may use code: [MENU] [*][8][0] [SET] or [START]
You may also call - 1800-211-7262 for Panasonic's capable Technical Support; be sure to have the serial number of the product ready.
3/5/2015 10:44:41 PM •
Panasonic...
Answered
on Mar 05, 2015
A FAX IN MEMORY
To print your faxes that are stored in the memory, removed and reload the paper and press the fax start.
7/13/2014 4:36:35 PM •
Panasonic...
Answered
on Jul 13, 2014
