20 Most Recent Goalsetter X554 54 Inch Glass Extreme In Ground Basketball System ES45654G3 Questions & Answers
What causes "toner not recognized" message?
Printers are programmed to reject non-genuine ink tanks and toner cartridges. Some of them are also designed/programmed to stop working altogether if you fit an aftermarket product and you will have to get a new printer. Most likely you have one of those. Never use non genuine products. You can try and pull the new genuine OEM toner cartridge out and refit it and see if the machine will reset and recognise it. If not I don't think you are going to get it printing again and you will be up for a new printer.. Follow some of the trouble shooting procedures in the user manual and if none of these work you are probably done with that printer.
1/4/2016 1:44:24 PM • Goalsetter X554... • Answered on Jan 04, 2016
2answers
This is my first year as a basketball coach and I don't know how long I should make each drill last. Any ideas?
It is important to keep your practices fast paced. By doing each drill for no more than five minutes, you allow each player to maintain a high energy level without getting tired of the specific exercise.
6/23/2019 5:45:32 PM • Basketball • Answered on Jun 23, 2019
3answers
Who was the first African American player in the NBA?
The first African American player to be drafted and play in the NBA was Earl Lloyd in 1950. In 1955, he even led his team to the championship.
5/31/2019 6:39:21 AM • Basketball • Answered on May 31, 2019
Can you talk to people on instargram how
https://m.youtube.com/watch?v=iwguLUWPGDc
4/4/2015 6:27:37 AM • Basketball • Answered on Apr 04, 2015
2answers
How do I fix a wobbly in ground basketball hoop
I would clear any loose debris, repack around pole with a dry concrete mix then add water to it make sure pole is level, brace if necessary and give 24 hours to set up.
1/25/2015 2:00:04 AM • Basketball • Answered on Jan 25, 2015
2answers
How can I get a better grip on the ball when I'm shooting?
As a high school basketball coach for a girl's team, the first thing I always tell them is to not use hand lotion. This adds to excess slippery sweat on the palms. You should be gripping the ball between your palms. When you shoot it, instead of tossing it from your palms, throw it with your arms.
8/11/2014 9:55:52 PM • Basketball • Answered on Aug 11, 2014
List of african antelopes
African antelope list kewel, kob, kirks dik, klipspringer and kudu
4/29/2014 6:50:30 AM • Basketball • Answered on Apr 29, 2014
How to fix my basketball hoop
Your either going to have buy a new one which I'm sure you want to be a plan Z. With that said, your going to have to weld it at a position that is not adjustable or is possible weld and screw 2 sides where it can move at the broken angle
4/16/2014 2:49:24 PM • Basketball • Answered on Apr 16, 2014
Huffy center court replacement backboard
you can go online like to ebay or some other dearler ship and search huffy center couter or (backboard) and there you go. Also its cheap
11/11/2013 9:17:18 PM • Basketball • Answered on Nov 11, 2013
What material are basketballs made of?
Basketballs are made of mostly rubber with a fiber layer wrapped around them for protection. It depends on which league you are referring to but this is the standard.
10/23/2013 12:05:08 AM • Basketball • Answered on Oct 23, 2013
What the Problem
You need to give us a better picture and description of your problem. It looks like you are working with a basketball goal that is laying down on the ground. Do you really mean only the "Net," or are you using the word net to mean the whole backboard mechanism? Are you talking about hooking the strings of the net to the orange "hoop?"Is this the first time you have tried to raise it, or has something changed after you have used it successfully for awhile? Is this new and you put it together yourself? If so, you probably made a mistake. Review the instructions, or ask a mechanical friend to look at it.Often the answer is easy - its asking the right question that is the hard part! Hopefully you can understand that you have not yet asked us the right question.
5/26/2013 4:35:56 PM • Basketball • Answered on May 26, 2013
How to install above the rim basketball hoop system
I believe this is the product you are referring to. The link is to the item on Sears' website. You should be able to find a manual there.
2/21/2013 12:03:04 PM • Basketball • Answered on Feb 21, 2013
Goalsetter X554 54 Inch Glass Extreme In Ground Basketball System ES45654G3 Logo
1 questions posted
Top Goalsetter Basketball Experts
Aron
Kolbrun...
Kardoc
Are you a Goalsetter Basketball Expert? Answer questions, earn points and help others
View Most Popular
  • Goalsetter Basketball
Most Popular Question
causes toner not recognized message
  • Basketball
