20 Most Recent
Braun Novamat 330 Slide Projector Questions & Answers
I have a Braun Novamat
Sounds like the belt. The USA service center is 800 735-4373. Otherwise contact the service center in your country.
Slide advance mechanism locks up
If you feel that it is working abnormally you can send it to service. In the USA Braun service is:
HP Marketing Corp.
PO Box 715
16 Chapin Rd. Unit 908
Pine Brook, NJ 07058
800-735-4373
Autofocus
Hi- I'm not at all familiar with this model so won't suggest a particular fix. However, in general, you may find some gear or other mechanical linkage, or perhaps a spring holding a gear in place has slipped. That caused the same symptm in some old Kodaks I know of. If you cannot figure it out AND you don't mind not having autofocus, you could disable AF. Inside you will find some sort of small light bulb. Disconnecting one lead will turn off that light and prevent AF from doing anything. If you end up taking that route, make sure you load all your slides in with the emulsion facing the same way (that's the less shiny side of the slide). This will reduce the amount of focus difference between slides.
Seeking replacement lamp
Try Bulbman.com or Bulbs.com or the retail chain called "Batteries PLUS Bulbs".
If they don't stock them, they should be able to point you toward someone who does. Good Luck !! Jim
