20 Most Recent Hino 2013 195 Questions & Answers
2answers
How to fix my k13c hino profia the problem is check engine and the truck is lost of power sence the check engine light on the magic eye board
You need to get the OBD codes read, this will identify the code for the faulty sensor/component
1/18/2019 1:25:47 PM • Hino 2013 195 • Answered on Jan 18, 2019
What is the recommended valve adjustment for SO5D Engine for Hino
Hi, for some reason I cant upload this link to a PDF for you but google this , it is a safe site Hino Valve Adjustment-Bayliner 32xx.com
1/18/2019 8:27:30 AM • Hino 2013 195 • Answered on Jan 18, 2019
What's wrong with it?
1/18/2019 1:04:56 AM • Hino 2013 195 • Answered on Jan 18, 2019
How to fix the problem of hino k13c diesel engine the problem is the chek engine and the truck is lost of power after check engine sign on the das board light on
You need to take this to the mechanic. This is not a user fixable issue.
1/18/2019 1:04:20 AM • Hino 2013 195 • Answered on Jan 18, 2019
What is the inlet and exhaust valve clearance of Hino 2009 model 6 cylinder diesel engine.. is there anyone to help me
The service and repair manual with diagram will guide you to fix the problem on your own easily and you will get the manual from the given link http://toolsnyou.com/
1/17/2019 6:21:53 PM • Hino 2013 195 • Answered on Jan 17, 2019
I have a Lithonia dusk to dawn flood light that's brand new there's also an on off switch. What does the on off switch control and for dusk to dawn should it be on or off?
  • When the switch is ON, the light operates in dusk-to-dawn mode. In this mode, the light automatically turns on at sunset and turns off at sunrise. When the switch is off, the light stays off.
4/18/2024 7:13:42 PM • Hardware &... • Answered on Apr 18, 2024
2answers
Grasslin QE7+ water heating timer dial problem
motor or gear failure
3/12/2024 10:39:33 AM • Hardware &... • Answered on Mar 12, 2024
Electrolux KOAAS31WX oven timer has maximum 20 minutes.
It sounds like the button contacts aren't making good contact. If you can get behind them you can spray them with electrical switch cleaner. ..
3/2/2024 6:36:01 AM • Hardware &... • Answered on Mar 02, 2024
How do I reset the ellis geyser timer to save electricity
Press P (program )on the timer and display will show then change the desired day, time and minute using the D+, H+ and M+ buttons. Press P again to set up another program and repeat the second step as above
2/26/2024 7:44:48 AM • Hardware &... • Answered on Feb 26, 2024
How do I program outdoor timer model 28486
Clear memory by pushing the reset button on the timer then reprogram using your current schedule when you want the timer to go off/on. Use the day and clock buttons for this then press enter
2/26/2024 7:35:43 AM • Hardware &... • Answered on Feb 26, 2024
Should the utiletech 24 hour manual timer make a humming noise while on?
No, the timer should not make any noise. The noise should be a result of loose connections which cause arcing, which can make a humming or buzzing sound. If you find that you still notice the sound, even when the main breaker is off then the problem is not electrical in nature.
2/26/2024 5:38:54 AM • Hardware &... • Answered on Feb 26, 2024
Micromark MM 9565 Timer. How to set up the timerMM9565micro Mark timer
Question edited for clarity and add a header in order with spaces and CAPS. It appears Micromark got out or the timer business. There is a similar one in another Fixya post, and a link to them. https://www.google.com/search?q=Micromark+MM+9565+timer ..
2/19/2024 10:55:33 PM • Hardware &... • Answered on Feb 19, 2024
How to turn water heating temperature up?
2/18/2024 9:47:44 PM • Hardware &... • Answered on Feb 18, 2024
How do I stop the timer on OXO digital timer # 1127980?
Manual
Instruction Insert
OXO https://www.oxo.com > wysiwyg > PDF_Files PDF The clock is set. • To set timer, press any button to enter timer mode. A timer icon will appear on the LCD screen. Press the and buttons to set the timer. 1 page ..
1/31/2024 2:06:27 AM • Hardware &... • Answered on Jan 31, 2024
2answers
I punched a fist size hole in the frame of bedroom door. How do i fix
Bondo it there is a wood bondo you could get or just use auto body works fine too
1/25/2024 2:59:22 PM • Hardware &... • Answered on Jan 25, 2024
I need a manual for CRMC-A310JBEO For Sharp Air Conditioner Remote Control
The Sharp Air Conditioner Remote Control CRMC-A310JBEO comes with two timer-related functions: TIMER ON and TIMER OFF. To set the timer on the remote control, press the Timer button, then use the Temp + or Temp - buttons to set the desired time. Wait 3 seconds, then the timer function will be activated. You can turn off either function by setting its timer to "0.0h".
1/24/2024 8:44:06 AM • Hardware &... • Answered on Jan 24, 2024
Hino 2013 195 Logo
10 questions posted
Top Hino Hardware & Accessories Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Hino Hardware and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Hino Hardware & Accessories
Most Popular Question
first piston shot jo5c all 4 valves
  • Hardware & Accessories
