20 Most Recent Cyberhome CH-DVD 300 DVD Player Questions & Answers
3answers
Dvd player keeps saying no disc when I try to play
dvd player keeps saying no disc when I try to play a dvd.what can i do? worked fine until about 3 months ago. started to say no disc when disc inserted but after opening and closing 3 to 6 times it would read.now it just wont read. any ideas?
2/17/2022 8:21:47 PM • Cyberhome CH-DVD... • Answered on Feb 17, 2022
3answers
The screen says no disc even when I put a DVD in
Dear friend,
Pls clean ur dvd palyer lense or replace ur lense
2/17/2022 3:16:19 AM • Cyberhome CH-DVD... • Answered on Feb 17, 2022
3answers
My dvd player only plays movies in black and white
my dvd player only plays movies back in black and white...not color. why?
1/4/2022 6:35:49 AM • Cyberhome CH-DVD... • Answered on Jan 04, 2022
2answers
Universal Remote Control CODE
You would need to contact the company that makes the remote and maybe Cyberhome for the code.
12/13/2021 6:13:00 PM • Cyberhome CH-DVD... • Answered on Dec 13, 2021
3answers
Need a update on blu-ray
There are 2 ways to update your blu-ray player. You can go to the manufactures website and download the update to a flash drive. Insert the flash drive into the player and follow the manufactures instructions. You can also update the firmware directly from the menu on the blu-ray player if it`s connected to the internet. Hopes this helps !
10/15/2021 3:23:09 AM • Cyberhome CH-DVD... • Answered on Oct 15, 2021
3answers
Does cyberhome ch-dvd 300 dvd player play burned mp4 movies?
the answer is "No". Your player cannot play MP4 DVD discs.
Take care.
6/11/2021 6:53:20 AM • Cyberhome CH-DVD... • Answered on Jun 11, 2021
2answers
Can I change my cyber home 300 to play all dvds?
my chdvd recorder 1500 does not resopnd
5/19/2020 7:06:26 AM • Cyberhome CH-DVD... • Answered on May 19, 2020
3answers
"no disc" message
sounds like you have a problem with the laser.laser has to focus a lot sharper to play dvd thus will play vcd but not dvd.Try cleaning first and if this doesnt work would suspect laser faulty,.
3/17/2020 3:52:13 AM • Cyberhome CH-DVD... • Answered on Mar 17, 2020
2answers
MY CYBERHOME DVD PLAYER IS READING INSERT DISC AT
I am sure problem on Laser,may be it does not read any disk.So all times it say insert disk.You can better opportunity replace this damage laser.
3/17/2020 3:41:25 AM • Cyberhome CH-DVD... • Answered on Mar 17, 2020
2answers
I'm having disc error messages or/and I cannot play dvds region 4
Below is a process to unlock the region's in that DVD player. There were a few methods try this one and post back letting me know how it goes.
1. Remove any disc in the tray.
2. Using the remote, turn the power off.
3. Turn the power on.
3. Open the empty tray.
4. Close the empty tray and wait until the player recognizes there is no disc in the tray.
5. Press "Menu, 1, 9".
6. A large rectangular area will appear in the bottom half of the screen; in the middle of the rectangle will be a single number that identifies the region to which the player is set.
7. Pressing the number keys on the remote will have no effect. Instead, use the up or down arrows above and below the "enter" button to change the region number. ("0" presumably is "region free".)
8. Once you have selected the region code (i.e., the number that now appears in the middle of the rectangle) press "enter".
9. Press the "opne/Close" button and the unit will save the selected code.
Hope this works let me know .Thank you for choosing Fixya! Feel free to leave a positive rating if this solution helps.
2/14/2020 1:41:26 AM • Cyberhome CH-DVD... • Answered on Feb 14, 2020
Screen says INSERT DISC after I have put the DVD in. What's wrong?
1. Incomplete disc information or scratched disc. This is the main reason for the issue. Before you try anything to examine or fix your DVD player, it's suggested that you make sure the disc you are trying to play is intact and well. If it's the problem of your disc, then trying to fix your DVD player does not help at all. In this case, you can copy the scratched DVD disc and then you may play it on your player machine. 2. The disc is incorrectly formatted. A common DVD disc or Blu-ray disc is formatted in various ways. You can find different DVD or Blu-ray disc types in the market, such as DVD-RW, DVD-R and 4K Blu-ray disc and so on if the disc is not formatted correctly in accordance with the player, then it will not be detected. You can use some software tools to correctly format your DVD disc. 3. The glitch of the DVD laser lens. Most of the DVD "No disc" problems are caused by the glitch of DVD laser lens. The cleaning DVD laser lens is not easy and requires patience and carefulness. You can start out by trying to blow away the dust if that doesn't work, you can try using a DVD cleaning disc.
1/14/2020 8:18:30 AM • Cyberhome CH-DVD... • Answered on Jan 14, 2020
2answers
Dvd player stops playing
Check out this website for troubleshooting and repair tips on your dvd player. Just paste the web address into your address bar. http://www.drx9000repair.netfirms.com/ They have lots information on these dvd players and also do repairs.
1/14/2020 7:11:55 AM • Cyberhome CH-DVD... • Answered on Jan 14, 2020
2answers
No sound on movie
what are you connecting the sound to the tv with?
Be aware that a component cable only carries video
http://akamaipix.crutchfield.com/graphics/infolib/homelib/hComponentVideoJack.jpg
cables that carry sound include scart
http://tech.petegraham.co.uk/wp-content/uploads/2007/03/scart.jpg
phono
http://akamaipix.crutchfield.com/graphics/infolib/homelib/hPhonoInputs.jpg
and optical
http://www.getdtvready.com/images/optical%20cable.jpg
If this is correctly connected then check in your DVD player menu for sound output, some DVD players wont auto-detect what type of sound cable you are using and you may have to set it to the type of output you are using.
Good luck.
1/14/2020 7:09:06 AM • Cyberhome CH-DVD... • Answered on Jan 14, 2020
2answers
Dvd player plays the movie but there is no sound
insert a normal music cd for 5 seconds eject. put your dvd movie back in
1/7/2020 8:11:58 AM • Cyberhome CH-DVD... • Answered on Jan 07, 2020
3answers
How to make wmv files to get play on this DVD player.
WMV won't play in the DVD, convert it to MPEG or DIVX.
10/30/2019 5:53:34 AM • Cyberhome CH-DVD... • Answered on Oct 30, 2019
Remote code list
HelloGet into this link, by copy and paste the link into the address bar of your browser. You can download the manual for your remote control from here.www.ask.com/questions-about/Radio-Shack-3-in-One-Remote-Codes
5/19/2018 9:50:49 AM • Cyberhome CH-DVD... • Answered on May 19, 2018
2answers
Code dvd LG for remote sonaki ev-rm9510
Wat is the code to dvp4000dvd player
1/22/2018 2:41:25 PM • Cyberhome CH-DVD... • Answered on Jan 22, 2018
Connecting a sony dvp-sr500h dvd player to sanyo
Here is the quick start guide https://docs.sony.com/release//DVPSR500H_qs_EN_FR_ES.pdf You seem to be using the Video & Audio connection. Start at the Player. Connect cables to YELLOW Video, RED Right Audio WHITE Left Audio Then go to TV and find the YELLOW input RED input and WHITE input. On some TV's they are separate, some combine them with the COMPONENT inputs (Component is 5 cables you will use 3 of them if you only have COMPONENT inputs) Some TV's have an input button on the remote but no on screen selection. Try pressing the input repeatedly to access the other inputs. Lastly you will not get upscaling if you are using the 3 cable hook-up. To get upscaling use an HDMI cable to connect. Be sure to not have both types of cables plugged in at the same time HDMI by itself is best. If you reply with the modelof the sanyo TV I'll try to get you more info.
1/5/2018 11:39:41 AM • Cyberhome CH-DVD... • Answered on Jan 05, 2018
Cyberhome CH-DVD 300 DVD Player Logo
865 questions posted
Top Cyberhome Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Cyberhome Televison & Video
Most Popular Question
push play button dvd player not work
  • Televison & Video
