20 Most Recent
Mercury Mark 75 Outboard Boat Motor (Mercury Marine) Questions & Answers
Install tilt and trim 75hp mercury
pending on how old your engine is coz the price of the full system is lots and mite be more than what your engines worth so check on price of engine with it fitted !
No spark
Most of those early 6cylinder mercks were dual coil fired on a dual points system with one coil firing 3 cylinders and the other firing the remaining 3 cylinders. They later came up with an electronic IR shutter system for running a switch box. Neither system was something for the average back yarder to be fooling with. The belt drive was critical for clearances and settings.SO- check to see if it has power to the ignition (about the only thing you can fix) and if it does- find some old timer Mercury guy to fix it for you.
The serial # on my Mercury 700 outboard is 4978147. What year is it?
Not all serial numbers give the year of manufacture. It will be in one of two locations on the label you got the serial number from. Look on the next line down under the actual serial number. There should be a four digit number. This is the year of manufacture. On some labels there is a small square in the lower right corner, next to the CE mark, with a two digit number in it. This is the last two digits of the production year. 02 is 2002, 04 is 2004 and so on.
