20 Most Recent
Oster Fpstdh0101 4tray Electric Food Dehydrator Questions & Answers
Oster Fpstdh0101 4tray Electric Food Dehydrator wattage
well, I'm guessing on the tag or label it shows something like this 120V ~ 60 hz 10.5 amps or120V ~ 60 hz 10.5A or120V ~ 60hz 11A (some manufactures round up if it falls into the same wire gauge)120Volts ~ 60hz 1260w or120Volts ~ 60HZ 1260 watt120V stands for normal operating voltage"~" means ac current60 herzts stands for how many cyclesSo if your unit shows only amps, it's really simple to figure out wattagetake the voltage shown, in my example it's 120, then multiply the amps, in my example it's 10.5. So 120 X 10.5 = 1260 wattsW = V * A and vice versus, if it only show wattage and you needed to know what gauge wire you needed to run a receptical to operate it AMPERAGE = VOLTS / WATTAGE
4/9/2013 12:55:54 PM •
Oster ...
Answered
on Apr 09, 2013
I have a Oster dehydrator Md# FPSTDH0101. When i
I
have a Oster dehydrator Md# FPSTDH0101. When i plug it in and switch on
the Off/On switch to the on position the heater and fan do not come on.
the switch lights up but it is not running. Help, does anyone have a
wiring schematic?
1/7/2013 1:22:40 AM •
Oster ...
Answered
on Jan 07, 2013
I need a manual for oster food dehydrator
go to the yahoo search bar and type in manual for oster food dehydrator if you have a make and model on it it will make the search more accurate ..in most cases you can find an online manual in a PDF file format...hope this helps.
8/26/2012 3:05:47 AM •
Oster ...
Answered
on Aug 26, 2012
