20 Most Recent Sunbeam 722 Auto Shut-Off Heating Pad Heater Questions & Answers
Why is it flashing F?
What the actual F???
1/23/2019 6:37:54 PM • Sunbeam 722 Auto... • Answered on Jan 23, 2019
2answers
F1 error on heating pad
Unplug & then plug in... will help for a little while, but the F1 will return. Sorry.
1/16/2016 8:19:43 PM • Sunbeam 722 Auto... • Answered on Jan 16, 2016
0answers
2answers
Sunbeam dual control heated mattress
Here's a discussion on the issue ::
http://www.fixya.com/support/t1520727-f2_fault_code_heating_pad
Charlie
1/25/2013 12:49:12 AM • Sunbeam 722 Auto... • Answered on Jan 25, 2013
I just got my new
Hi
As its new I would recommend you to get use warranty and get it repaired/replaced. However, if you still want to do this yourself then pull out the main wire box located inside the pad and then take it apart and use hair dryer to dry the electronic control board, this should work, however remember that opening it will void the warranty. Hope this helps...please post back for further assistance.
Daniel
5/26/2011 7:38:01 PM • Sunbeam 722 Auto... • Answered on May 26, 2011
0answers
Flashing f2 message
This means that the controller for the heating pad has a short. Water will cause the controller to short out. If water is spilled on the controller you can unplug the cord and take the controller apart and use a hair dryer to dry the controller out. If no water has been spilled on the controller you can take it apart to make sure all of the wires are still soldered in place.
1/19/2011 4:42:52 PM • Sunbeam 722 Auto... • Answered on Jan 19, 2011
My control mechanism has error message F1 now F2
My electric blanket had the same message and I could not find anywhere to answer question. Sunbeam said to look on th cord tag and this was no help. I finally pulled out the main wire box inside blanket and took apart to see if there was anything obvious. All solders looked fine but then I noticed a drop of water. Used a hair dryer to dry the electronic board, reassembled and it worked. Must have been a water short.
12/3/2010 2:58:39 PM • Sunbeam 722 Auto... • Answered on Dec 03, 2010
Control says FF?
What control, brand, model # etc.? An educated guess would be that you have a gas forced air system. FF would typically mean Flame Failure. Pull flame sensor, clean rod with steel wool until shiny again and reinstall. Your flame sensor will have one wire going to it. Located at the opposite side from the igniter. It will have a ceramic base with stainless steel probe protruding into the flame. Hope my guess helps.
10/7/2009 6:19:23 AM • Sunbeam 722 Auto... • Answered on Oct 07, 2009
Heating & Cooling Logo
38 questions posted
Top Sunbeam Heating & Cooling Experts
ZJ Limited
ZJ Limited
Paul Carew
Jay Finke
Jay Finke
Are you a Sunbeam Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Sunbeam Heating & Cooling
Most Popular Question
control mechanism error message f1 now
  • Heating & Cooling
