20 Most Recent Microsoft Outlook 2010 Questions & Answers
6answers
Mac Mail migration to Windows Outlook 2010 Can
Having a google search can land you in a pool of solutions for your problem. Or you can use applications to solve your issue. There are various applications available for this problem. Have look at one I know:- Apple Mail to PST Convert - Convert Apple Mail Emails to Windows Outlook PST Hope this helps Thank you
11/27/2023 10:17:10 AM • Microsoft... • Answered on Nov 27, 2023
3answers
I can't receive my mail.
Hello, What type of server that your e-mail account works with? If you are using POP3 or IMAP account, please configure Incoming mail server. You should try the given below solution to resolve the occurred issue: Sol 1: Open "Microsoft Outlook" >> Click on "File" tab >> "Account Settings" >> "Account Settings", locate your account and click on change.... then click on "More Settings" to configure Incoming mail server. receive-mail-gmvtzn34zba02bnrp4mic5sd-5-0_0.png If you are using Microsoft Exchange account, check if you use cached exchange mode. If not, enable it. Click on "File" tab >> "Account Settings" >> "Account Settings" locate your exchange account and click on "change...." Under server settings, check Use cached exchange mode. You can check another setting to help resolve being able to send but not receive e-mail messages. You can set up Microsoft Outlook to check for new e-mail messages at intervals of one minute to 1,440 minutes (one day). On the "Send/Receive" menu, point to "Send/Receive Groups", and then click on "Define Send/Receive Groups". Select the group that contains the e-mail account that you want to regularly check for messages. Under Setting for group "group name", select the Schedule an automatic send/receive every x minutes check box. Enter a number from 1 to 1440 in the minute's box. receive-mail-gmvtzn34zba02bnrp4mic5sd-5-2_0.png Click on "Close" button. On the Send/Receive menu, click Send/Receive All folders. Sol 2: Open "Microsoft Outlook" >> Click on "File" tab >> "Account Settings" >> "Account Settings" >> Click on "Change Folder" button >> Change from whatever it was to: Outlook Data File - Inbox receive-mail-gmvtzn34zba02bnrp4mic5sd-5-5_0.png Close the dialog, click on send/receive or press F9 button and see if it works. Thanks & Regards Captain Ashish
7/15/2022 10:28:24 AM • Microsoft... • Answered on Jul 15, 2022
2answers
Is there a method to repair corrupted Outlook 2010 Address Book?
To fix this you can remove the Outlook Address Book service, restart Outlook, and then add it again as indicated by the steps above. Sadly this workaround will not work in Outlook 2007, 2010 and 2013 as removing the Outlook Address Book service is not supported in these versions. In this case, you must recreate your mail profile. (Re)creating a mail profile.. 1. Press the button Add... -Do NOT use Copy... not even when you want to recreate your mail profile or you'll end up copying the corruption as well. -Do NOT delete your old profile, not even when it is corrupted, before you verified that the new one works. You might want to lookup some account settings afterwards. 2. Enter a name for your new Mail Profile. 3. Select to add a new mail account. 4. Make sure you choose the correct account type. Ask your ISP or administrator if you do not know this. -If you are using Live Hotmail, Gmail, Yahoo or AOL, you can find the settings you need here. -In Outlook 2007, Outlook 2010 and Outlook 2013, you can simply type your desired display name, email address and password and Outlook will try to determine and configure your account automatically. If this fails you can still choose to configure it manually with the information provided by your ISP. If actions on above can't get back your address book, then try third party software Address Book Repair Toolbox http://www.addressbook.repairtoolbox.com/
5/23/2022 1:08:08 PM • Microsoft... • Answered on May 23, 2022
9answers
Damaged PST file, any hope?
Knowledge bases as possible resolutions corrupted .pst file... https://social.technet.microsoft.com/Forums/en-US/3b6cc28f-469a-4623-8033-ee478a9fdb4e/recover-outlook-emails-and-contacts?forum=outlook - the same resolved issue http://www.filerepairforum.com/forum/microsoft/microsoft-aa/outlook/1511-is-there-chances-to-recover-pst-after-virus-infection - user community where people also discuss outlook issues https://fixpstfile.recoverytoolbox.com/ Recovery Toolbox for Outlook - a solution, when another methods don't effectively work Easy steps to solve corrupted .pst file... 1. Click the Start menu and in the search or Run dialog, Type C: Program Files Microsoft OfficeOffice12SCANPST.EXE and Press Enter. 1a. Optional: You can also find this file by Clicking My Computer and browsing to the destination. Once there Double-Click SCANPST to open it. 2. Type in or Browse to the location of your Outlook PST Files. Press Start to begin the repairing. Note: Microsoft Outlook 2007 must not be running to complete this step. Step 2 Tip: By Default, PST files are stored in the following locations: Windows Vista & Windows Server 2008: C: UsersMrGrooveAppDataLocalMicrosoftOutlook Windows XP: C: Documents and SettingsMrGrooveApplicationDataMicrosoftOutlook 3. The repair tool will offer you a quick summary of what errors it has found in its initial scan. Click the checkbox for Make backup of scanned file..., and then Set a Location to save your backup file. To finish the process, Click Repair and Outlook will go through and fix all of the errors found in your PST file (hopefully......).
5/20/2022 12:38:27 PM • Microsoft... • Answered on May 20, 2022
7answers
Import Mac Entourage files in Outlook 2010
If your mail account is configured on both systems as an IMAP account since the mail is on the server, both devices would see the same mail. Or Try this link :Entourage to Pst Converter
2/24/2022 10:48:04 AM • Microsoft... • Answered on Feb 24, 2022
6answers
Export apple mail data to Windows Outlook 2010
2/12/2022 12:12:29 AM • Microsoft... • Answered on Feb 12, 2022
tip
How to Merge Multiple Outlook PST files into single one?
With the extended usage of Microsoft Outlook, the number of PST file may increase enormously. Lead to unmanageability problem and in such situation of mishandling, may result in Outlook files corruption or inaccessibility of PST file. Therefore, this calls for the merging of PST file into a common file to handle them smoothly. To merge multiple PST files into a single PST file manually with Outlook: First, open the PST files within your Outlook. In every version of Outlook, you are allowed to open the additional PST files. For Outlook 2007, you need to navigate through File menu > Open > Outlook Data File. After that browse to the PST file location and open the file in the system, select it and click OK. For merging your files you must repeat this for multiple PST files and move the Outlook content between PST files by either dragging and dropping them or by highlighting the content, right-clicking it, and selecting Move To from the context menu. Then navigate to the destination folder, and click OK. By this process, the content will be moved to the destination folder and removed from the source one. If your PST is large, say more than 1GB of data, then I recommend segmenting the files into two or more smaller parts and then move them in parts. This task may get tedious if you have plenty of PSTs and a lot of content. Then the third-party applications can help you complete your task in an easy and secure way. PST Merge Software can also provide you with the useful feature that could help you maintain you PSTs in Outlook.
How do you import contacts
When you install Outlook 2010, it automatically converts the Personal Address Book that you used in an earlier version of Microsoft Outlook. Outlook 2010 then adds the converted data to your Outlook 2010 Contacts folder. If Outlook 2010 does not automatically convert your Personal Address Book, you can import your Personal Address Book to Outlook 2010. To do this, follow these steps:
  1. Start Outlook 2010.
  2. Click the File menu.
  3. Click Open, and then click Import. The Import and Export Wizard opens.
  4. Click Import from another program or file, and then click Next.
  5. Click Personal Address Book, and then click Next.
  6. Click Browse, locate the Personal Address Book that you want to import, and then click OK. Note Earlier versions of Outlook assign a .pab file name extension to a Personal Address Book. By default, Outlook stores the Personal Address Book in the following folder: C:\Documents and Settings\username\Local Settings\Application Data\Microsoft\Outlook
  7. Click Next.
  8. Click Finish to import the Personal Address Book.
4/15/2020 9:14:30 AM • Microsoft... • Answered on Apr 15, 2020
How to Fix Something Went Wrong Error Message In my Outlook or Hotmail email account?
Look like temporary error you had. I hope it would be fixed by now. Otherwise try to open the account in different browser. If that don't work, try to reset password with alternate email id.
10/19/2019 11:28:52 AM • Microsoft... • Answered on Oct 19, 2019
How to configure outlook calendar to sync with winphone 7 calendar
The most ideal path is to download the Hotmail connector and after that sync up your Outlook mail/timetable with the Live ID, you used to set up the Windows Phone. It will stay up with the latest continuously and give a simple method to get to your mail from the web, phone, or work area.
6/15/2018 6:46:38 AM • Microsoft... • Answered on Jun 15, 2018
How to open Outlook 2010 email files backed up to a CD?
You will need to import the data from the PST file back into outlook . It should go into a personal folder After this process you can then copy the files into your email inbox or leave them in a personal folder or create a personal folder on a server mapped drive and then import email data to this folder so it gets backed up hopefully on the server. If you bak up the server.. https://support.office.com/en-us/article/Import-email-contacts-and-calendar-from-an-Outlook-pst-file-431a8e9a-f99f-4d5f-ae48-ded54b3440ac
5/24/2017 11:29:40 PM • Microsoft... • Answered on May 24, 2017
I am having an issue that when I try to print an email, it only prints the first page and not the entire email. I am not able to find an option that allows the entire email to be printed out
This happens when you print from the browser print or the "right click" menu.. you MUST use the print from the program, a dialog window showing the email should pop up and say how many pages
1/29/2017 4:58:15 AM • Microsoft... • Answered on Jan 29, 2017
I LIVE IN AN APARTMENT COMPLEX IN NASHVILLE, TN.
Normally, you need to use the settings provided by your ISP.If you need technical support, I suggest you contact The Best Pc Doctor Team.www.thebestpcdoctor.com877 407 9229(Toll free)
12/29/2016 12:01:37 PM • Microsoft... • Answered on Dec 29, 2016
Why doesn't it work correctly?
Also, make sure nothing is in your Outbox folder. If any emails are stuck in this folder, it will cause issues.
8/23/2016 3:54:17 PM • Microsoft... • Answered on Aug 23, 2016
Incoming emails are not appearing in the inbox folder of Microsoft Outlook 2010.
Could be your Outlook profile got corrupted somehow. If you use your account settings on another PC w/Outlook does the trouble follow? Or is it strictly w/your PC? Obviously, other profiles are working fine (your partner's). One solution might be to backup your .pst file to the C: drive or a USB drive, completely delete your old profile, and build a new one. Once your confirm that email is working properly, then attempt to reload your old .pst file to get all your old email back.Something else you could try is to open Outlook in Safe Mode. This will run Outlook with minimal addons in order to eliminate the possibility that some sort of addon is the culprit.You can use one of these methods to start Outlook using a command line switch:Hold Ctrl key as you click the Outlook shortcut.If you use Vista or Windows 7, type outlook.exe /safe in the Start Search field on the Start menu then press Enter.
8/23/2016 3:53:30 PM • Microsoft... • Answered on Aug 23, 2016
2answers
Export data from outlook 2010 to another outlook 2010
To export Outlook 2010 data follow below mentioned steps : 1. Click on File -> Open -> Import2. Select Export to a file and click Next.3. Select Outlook Data File(.pst) and click Next.4. Now Select the items or folders like Inbox, calendar, tasks, contacts etc. which you want backup and then click Next.5. Mention a location where you want to save your backup and click Finish.Now you can transfer this backup to any portable device like Pen Drive, portable hard disk or compact disk and then can import it to another computer. RegardsJane
6/8/2016 3:36:14 AM • Microsoft... • Answered on Jun 08, 2016
2answers
Cannot reply to emails on chrome
You have to reset chrome to work it properly. You can reset it just following some steps. 1) Open Chrome Setting. You will see the same screen as shown in following image. cannot-reply-emails-chrome-w3i35ygaym0a2mtgexp5w2fh-5-0.png 2) Then scroll down this screen and at the bottom of screen you will see show Advance setting, click on this link. You can see the same screen image at below image. cannot-reply-emails-chrome-w3i35ygaym0a2mtgexp5w2fh-5-2.png 3) Then this will expand towards down again at the bottom of screen you will see Reset setting button, Just click on it. You can see the exact screen at below image. cannot-reply-emails-chrome-w3i35ygaym0a2mtgexp5w2fh-5-5.png Now login again to your mail and try to reply emails. I hope you will now able to reply mails on Chrome.
3/4/2016 6:19:09 AM • Microsoft... • Answered on Mar 04, 2016
Microsoft Outlook 2010 Logo
129 questions posted
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Microsoft Computers & Internet
Most Popular Question
method repair corrupted outlook 2010
  • Computers & Internet
