20 Most Recent
Google Inc (GOOG) Questions & Answers
SANSUI FR-D45 TURNTABLE
It sounds like there might be an issue with your turntable. The behavior you described suggests that there could be a problem with the power supply, the motor, or some other component. Here are a few troubleshooting steps you can try:
- Power Supply:
- MakSsure the power supply is working properly. Check the power cable and the outlet.
- If the turntable has a power switch, ensure it is in the correct position.
- Belt or Drive System:
- If your turntable has a belt drive, check if the belt is properly placed and not damaged. If it's a direct-drive turntable, ensure there are no issues with the motor.
- Auto-Stop Feature:
- Some turntables have an auto-stop feature that turns off the motor after a set amount of time. Check the user manual to see if your turntable has this feature and how to adjust or disable it.
- Platter Alignment:
- Make sure the platter is properly seated on the spindle. If it's misaligned, it could trigger an automatic shut-off.
- Automatic Tonearm Return:
- If the tonearm is moving over and causing the turntable to shut off, there might be an issue with the automatic tonearm return mechanism. Check if there's any obstruction in the tonearm's path.
- Internal Components:
- If the issue persists, there could be a problem with internal components such as the motor or electronics. In this case, it might be best to contact the manufacturer's customer support or seek professional assistance.
How long is cyclobenzappine good for
Cyclobenzaprine is a muscle relaxant medication that is typically used to treat muscle spasms and pain caused by sprains, strains, and other muscle injuries. The length of time that cyclobenzaprine is good for depends on several factors, including the strength of the medication and how it is stored.
Typically, cyclobenzaprine has a shelf life of about 2-3 years when stored at room temperature, away from light and moisture. It is important to check the expiration date on the medication before using it, and to discard any medication that has expired.
Once you open the bottle, you should use the medication within the time frame specified on the package or by the pharmacist. If you no longer need the medication, or if it has expired, you should dispose of it properly, in accordance with the guidance of your pharmacist or healthcare provider.
Keep in mind that medication can lose potency or become contaminated if not stored properly. It's important to store cyclobenzaprine in a cool, dry place, away from light and moisture, and to keep the bottle or package tightly closed when not in use.
If you have any doubts or questions about the quality or expiration of your medication, please consult your pharmacist or healthcare provider for guidance.
How do i stop all ads on pages
You have to use one designed for whatever browser you are using. I frequently use Chrome, and have found "AdRemover for Google Chrome" to be excellent.
What does forum mean
A forum is a place where people share thoughts online about a common interest. Typically, you will need to register with the forum and may need to wait to be approved. Once registered, you would login to the forum and read "threads", post to them to share, or start a new thread. A "thread" is generally a term used to describe a topic and it's discussion entries made by various people sharing on that topic. Forums are great places to share information and learn about items of interest.
What is a steeple cast in fly fishing
A steeple cast is a move made by sending the fly high above you to backcast, rather than behind you as would normally be done. When the fly is high, you snap it forward to its target. The steeple cast is used when there is no adequate space at your back for a normal backcast. Wanna see it? Look here: https://www.youtube.com/watch?v=yxpz-rO9Dbc
What is the gcf of 84 and 42
The greatest common factor of 84 and 42 is 42. Of course, the term refers to the largest number which is evenly divisible into the givens. So, since 2 X 42 = 84 and 1 X 42 = 42, and since there can be no factor of any number which is greater than that number itself, the gcf of 84 and 42 must be 42. Good luck. Truly.
HOW OLD IS JOHN LEGEND
John Roger Stephens, who uses John Legend as his stage name, was born on December 28. 1978. Accordingly, as of this writing (July 2014), he is 35 years old.
What does serendipity mean
Serendipity is the occurrence when something useful is found or discovered which was not specifically sought or expected. Willard Keith Kellogg serendipitously discovered a process for flaking corn while experimenting with vegetarian recipes in the kitchen of an Adventist sanitarium directed by his brother, John Harvey Kellogg, the notorious quack physician and masturbationphobe.
Operating manual for Bionaire Model BCM 7913-CN
I don't have access to a specific operating manual for the Bionaire Model BCM 7913-CN humidifier. However, in general, a humidifier operating manual should include information on setting up the device, cleaning and maintaining it, and troubleshooting any issues that may arise. If you no longer have the manual that came with the device, you may be able to find a digital copy on the Bionaire website or by contacting their customer service for assistance.
Google chrome crashed or doesn't word when i download it what can i do?
There are a few things you can try if Google Chrome crashes or doesn't work when you try to download it:
- Check your internet connection: Make sure that you have a stable internet connection and that your computer is not blocking the download.
- Restart your computer: Sometimes, simply restarting your computer can resolve issues with Chrome not working or crashing.
- Check your antivirus software: Some antivirus software may block Chrome from downloading or running. Try temporarily disabling your antivirus software and then try downloading Chrome again.
- Clear your browser's cache and cookies: Clearing your browser's cache and cookies can help resolve issues with Chrome not working or crashing. To do this, go to the settings of your browser and look for the option to clear your cache and cookies.
- Try downloading Chrome in a different browser: If you're unable to download Chrome in your current browser, try downloading it in a different browser (such as Firefox or Edge) and then install it.
- Check the version of your operating system: Google Chrome may not work properly if your operating system is not up to date. Make sure you have the latest version of your operating system installed before downloading Chrome.
- Try downloading the Chrome offline installer: If you are unable to download chrome using the regular installer, you can download the offline installer from the official
