20 Most Recent Fujitsu LifeBook AH530 NoteBook Questions & Answers
3answers
I want to completly remove Windows and repl,ace it with Win XP Pro
If you have a valid copy of xp pro, then just insert the disk and boot from it when asked. when you are asked about an install, choose a clean or new install and everything will be erased and you will start over. Be advised that you will need to get the lifebook drivers burned to a disk before you start.
4/25/2019 5:49:10 AM • Fujitsu LifeBook... • Answered on Apr 25, 2019
I forget BIOS password for my fujitsu lifebook a
1. Turn off the laptop2. Remove the power cord3. Remove the battery4. Dismantle back screws and pop open the cover.5. Locate the Dry cell (Button Cell)6. Remove the button cell from the laptop.7. Wait for 10 Seconds8. Put back the button cell.9. Fix the back cover by re-screwing10. Put back your laptop battery11. Turn on the laptop12. Thats it !
10/4/2018 11:58:48 PM • Fujitsu LifeBook... • Answered on Oct 04, 2018
Some keys are not working on Starup (Random)
Your problem seems to be from the keyboard. Even if it looks good if the keyboard tape is out of whack or some key is no longer working, it can happen that you say, so I change the keyboard.
11/21/2017 8:00:23 PM • Fujitsu LifeBook... • Answered on Nov 21, 2017
Fh13ff-238 web cam shows black in screen.also no option to enable it in by bios 1.19
Can you locate and download the correct driver for your computer using this link? Drivers Downloads It sounds like you may have installed an incorrect camera driver.
3/17/2015 2:19:30 PM • Fujitsu LifeBook... • Answered on Mar 17, 2015
My web cam shows black also in camera test which is build in ah530(fh13ff-238)
Hi, Go to bios setup by pressing f2 and check that the "internal camera" is enabled. Regards
3/7/2015 3:58:55 PM • Fujitsu LifeBook... • Answered on Mar 07, 2015
How can I clear a CMOS configuration in a Fujitsu AH530 ?
Place a short on the battery holder's + and - tabs for a minute or two. It has to be on long enough to discharge a capacitor on the motherboard. This will delete the bios password only.
11/19/2014 8:57:22 PM • Fujitsu LifeBook... • Answered on Nov 19, 2014
0answers
2answers
MY fujitsu lifebook ah530 keeps
Your display setting does not match.You need to setting the display right way.Or you uninstall and install the VGA (graphics)driver again,and simply restart the PC.
Hope it will solve your problem .
6/14/2014 12:54:01 AM • Fujitsu LifeBook... • Answered on Jun 14, 2014
Built in microphone not working
1. Ensure the most recent hardware driver for your operating system. 2. Enable device through control panel, bios menu during system start up, and combination of function keys. 3. Do not have external mic connected.
5/29/2014 12:50:34 AM • Fujitsu LifeBook... • Answered on May 29, 2014
My fujitsu lifebook ah530 screen blinks constantly plz help
Set the screen-resolution to 640-by-480, to see if the blinking stops. If it does, set the screen-resolution to 800-by-600, to see if it this higher resolution is supported. Also, try 1024-by-768.
5/16/2014 7:10:58 PM • Fujitsu LifeBook... • Answered on May 16, 2014
Where is the inverter for fujitsu lifebook ah530
lcd inverter are commonly found at the bottom of the LCD screen after you'd remove the edges cover. try to remove the VGA cable from the laptop and see if the screen will blink or flash. thanks
4/2/2014 7:42:26 PM • Fujitsu LifeBook... • Answered on Apr 02, 2014
Fujitsu Lifebook A530 display has rotated 180 degrees. Don't know how don't know how to fix. Please help.
Ctrl+Alt+Arrow Keys continuously until it comes to normal
3/9/2014 3:52:28 PM • Fujitsu LifeBook... • Answered on Mar 09, 2014
0answers
Ah530 lcd
Be the first to answer 2/17/2014 11:26:59 AM • Fujitsu LifeBook... • Posted on Feb 17, 2014Be the first to answer
0answers
0answers
Fujitsu LifeBook AH530 NoteBook Logo
161 questions posted
Top Fujitsu Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
LifeBook Fujitsu
  • LifeBook Fujitsu
Most Popular Question
  • Computers & Internet
