20 Most Recent
JCPenney Gyropter RC Helicopter Questions & Answers
Chopper spins clockwise . How do I fix it
It is spinning around because one of the rotors is not spinning at full speed. This happens when you bump a spinning rotor against something. Determine which one it is by observation or logic (i.e, the one that turns clockwise will produce counterclockwise torque, which is to be balanced by the other rotor spinning counter clockwise. So the counter clockwise spinning rotor is slow) Tighten the screw that holds that rotor that is spinning more slowly. Use the screwdriver that came with the spare parts.
12/29/2013 10:25:15 PM •
JCPenney...
Answered
on Dec 29, 2013
I cHarged the helicopter and
try to play around with the trimmer.. i had the same problem but then guessed it was the trimmer and iwas right!
12/7/2013 9:00:18 PM •
JCPenney...
Answered
on Dec 07, 2013
The gyropter will not charge
Check the charger adaptor if it has any output power. If no power comes out replace the adaptor.
Check also the battery terminal, it might already corrode and needs clean up.
If all does not work, the battery in the helicopter is already malfunctioning.
hope that helps you out!
12/7/2013 8:58:40 PM •
JCPenney...
Answered
on Dec 07, 2013
