20 Most Recent Hitachi 53SWX10B 53" Rear Projection Television Questions & Answers
Tv power (redlight will come on powering the TV then back off
If the model here listed is correct it may be the actual power switch--it like all the front controls is a tiny micro switch--only supposed to work when pressed but can and does fail in this way--How to prove/disprove this?Someone needs to remove the front keyboard and unsolder that 2 pin switch---remote will with the board back still turn set on.If it works that way either just use the remote or search for the keyboard and replace if can find one.Only other issue possible is the microprocessor in the set could be bad and we do not want that-----both the front buttons on set and the remote go to the same place inside the set but the keyboard has priority over the remote.If power button bad, button on the remote will not stop or correct this.SD TECH
4/22/2012 2:56:01 PM • Hitachi 53SWX10B... • Answered on Apr 22, 2012
I have a Hitachi 53swx10b. The sound is starting
There is not an easy fix for this problem with this model.This set uses a surround sound audio board that processes all audio. Our shop no longer repairs the boards as it can be very time consuming and usually we send the board out to a national company for rebuild.Problem is solder connections on tiny flat pack parts on both sides of the board break and I saw several where set was only months old, at that time Hitachi sold the board but it is no longer available from themThe Rebuilders (last time I used them) charged about 200 including shipping as you have to remove the board and send it in. Removal of the board is not hard and I can tell you where to look for it.Sorry if this is bad news but it is what your problem is.Let me know if you have questions as I am here to help.SD TECH
4/18/2012 2:30:42 PM • Hitachi 53SWX10B... • Answered on Apr 18, 2012
No sound on tv
Hello,there are so many reasons why your TV won't bring out sound. You need to troubleshoot first, in order to get to the root of the problem, before a solution can be proffered.First, connect a DVD player to the TV, observe if there is going to be sound. If there is still no sound after connecting the DVD player to the TV, proceed to the next step. "The reason why I asked you to connect a DVD player to the TV is to confirm if the problem is simply not from the audio cord connected to the TV."Second, get an headset, connect it to the earphone jack of the TV and observe if there is going to be sound. If there is no sound, then it is glaring now that your TV is having a defective sound card/IC that's why it is not bring out any sound. (Note that connecting an headset to your TV is optional because not all TV's has a space for headset). "The reason why I asked you to connect an headset to the TV is to also confirm if problem is not from the TV speaker. Though TV speaker problems are rare but sometimes, the TV speaker might be defective or the speaker wires may have loosed contact or cut into two, due to one reason or the other. But if the headset doesn't bring out any sound from the TV, then it is not so."If none of the above seems not to be the cause of the problem, then the above troubleshooting has confirmed that the TV has got a defective sound card/ic. The sound IC/card of the TV has to be replaced for the TV to bring out sound again.To be honest with you, replacing or fixing the sound card/ic of your TV requires the ability or experience to do so.Now, if you are convinced you can fix or replace this yourself, please reply so that i can help you further. And make sure you troubleshoot first, before getting back to me.Regards.
11/11/2011 3:16:01 PM • Hitachi 53SWX10B... • Answered on Nov 11, 2011
Was watching my Hitachi 53SWX10B
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom (look for discoloration of the circuit board around the base of the capacitor) need to be replaced.
If you repeatedly turn it off and on, eventually it'll probably stay on, but every time you turn it off, the unit will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for some time and then try again.
If you aren't tech savvy, don't worry, read the rest of this solution and watch the videos.
If you are handy with a soldering iron and can identify the power supply and/or inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are SURE it's only doing supply output ripple filtering,
and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors, amplifiers, computer power supplies and motherboards, and other electronic equipment.
The parts are cheap, and skill required is minimal.
A great parts source is Digi-Key, and you can order the parts online at www.digikey.com
They typically cost under a dollar a piece plus a flat shipping rate.
The parts usually arrive one business day later.
If you watch the third video, you will see that even someone with no soldering experience can perform these repairs as demonstrated by the woman in the video.
7/19/2011 2:36:58 AM • Hitachi 53SWX10B... • Answered on Jul 19, 2011
2answers
Hi, I have a Hitachi 53swx10b projection tv. the
Ur tv convergence are dead.U know how to solders?Must replaced 2 STK convergence ICS,and some or all the resistors.Tries Websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost $300-350 for parts and labors.
3/30/2011 7:58:29 PM • Hitachi 53SWX10B... • Answered on Mar 30, 2011
The picture is very blury
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
3/9/2011 9:15:40 PM • Hitachi 53SWX10B... • Answered on Mar 09, 2011
I HAVE A HITACHI 53WX10B
Magic focus button don't work or datas never reaches 100%.Tv have a problems,known as a convergence problems,it dead.Tv have colors lines R,G,B mis alingments,have colors shadows pictures or a 3D pictures look alike?The tv have a dead convergence board.The tv convergence board have 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be replaced to solved the tv convergence pictures problems.The shop,will cost like $300-350 for parts and labors.
12/4/2010 8:35:28 PM • Hitachi 53SWX10B... • Answered on Dec 04, 2010
My picture looks almost 3D, even after using the Magic Focus
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
10/15/2010 3:26:57 AM • Hitachi 53SWX10B... • Answered on Oct 15, 2010
Shadows on left side of screen,right side has no shadows
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
7/3/2010 6:50:45 AM • Hitachi 53SWX10B... • Answered on Jul 03, 2010
I see red and green silhouettes of the images
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony2_bing.gif,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer2_bing.gif, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
4/14/2010 4:32:51 AM • Hitachi 53SWX10B... • Answered on Apr 14, 2010
I have no sound
Make sure the speakers are turned on. In the audio section of the main menu, under advanced settings there is a box labelled "internal speakers". Make sure this box is checked. I hope this helps. Thanks for using fixya.
1/14/2010 1:51:27 PM • Hitachi 53SWX10B... • Answered on Jan 14, 2010
I have a Hitachi 53SWX01b tv and are getting blue
This model uses two of the STK-392-110 or 150 convergence IC's---if magic focus will not correct it or if Blue will not move in the convergence mode--both chips along with any resistors that protect them need to be replaced and the set adjusted.
You can buy the parts for this repair for less than 25 dollars total. The question is are you able to do the repair?
With the back off of the set(unplug set first) the chips will be as you look from the back on the right side--they are Black and about 2 1/2 inches wide X 1 1/2 inches tall with 18 pins each---they will have the Stk number printed on them in white.
To do this repair you need to be able to get at the chips and unsolder/replace them and also check all the resistors around them--any resistor near them that is discolored or white in the middle is bad.
I usually check all the resistors there when I do this type of repair--I have done hundreds of these sets. It usually takes about 1 hour to do it.
If you CANNOT DO this repair--shop around in your area as most shops charge 300-400 for this repair--if the say it has to go to the shop----keep looking--any good tech can do this repair in your home.
IF YOU HAVE ANY QUESTIONS OR NEED ADVICE, do not hesitate to let me know--I am here to help people----FYI, in my area I do this repair for 200-250 total in the home of the customer.
These are very good sets and much more dependable then the Plasma and LCD sets---not to mention it is much cheaper to repair it than replace it.
After the repair the set should not have this problem for 3-5 years and many sets go 8 years or more.
Regards, SD TECH
10/21/2009 9:14:59 PM • Hitachi 53SWX10B... • Answered on Oct 21, 2009
Color on Panasonic 2004 is off and appears to be warped
It sounds like a convergence problem; most of these sets use two convergence IC chips that both need to be replaced; usually this can be done right in your home.
8/16/2009 3:47:06 AM • Hitachi 53SWX10B... • Answered on Aug 16, 2009
Picture jumps on projection tv
There is not more knobs for V hold so there is a circuit in its place that is going out and needs repaired and it is worth it because these TV are great when they are fixed it will get worse do not bang on it your going to loosen the part that is going out and may cause it to heat up and the list goes on.. take it in you be glad you did if this info helps please rate it fixya thanks Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
4/26/2009 3:39:32 AM • Hitachi 53SWX10B... • Answered on Apr 26, 2009
Hitachi 53SWX10B has picture but
Hi, not good news, you have a bad surround module and this is a VERY difficult repair job, most techs send it to PTS and then they don`t get it right about 10% of the time either, Have a tech pull the board and send it out theres nothing you can do to repair it, sorry for the bad news, video-tek
2/5/2009 12:52:32 AM • Hitachi 53SWX10B... • Answered on Feb 05, 2009
2answers
Color is warped and wrong
A convergence amp has failed. Very common. Plan on just replacing both STK modules (big flat circuit modules mounted on a big heat sink) with upgraded parts. Good ones cost about $40 each. Then readjust the convergence. Total cost at a shop is $250-$400.
Hope Ya Fix It.
1/29/2009 5:24:06 AM • Hitachi 53SWX10B... • Answered on Jan 29, 2009
Picture format
The HD reciever shouldn't be the problem.
If you recieve an image with a 4:3 aspect ratio, the image will be displayed at that ratio on your HDTV unless you specify otherwise. To do so go to your TV's Setup screen
setup
Choose picture formats
select smooth wide as your default
***Some digital (ATSC format) stations may transmit 4:3 images in a way that will not allow expansion. You will be unable to adjust the picture format.
Hope this helps!!!
J
1/16/2009 1:04:04 AM • Hitachi 53SWX10B... • Answered on Jan 16, 2009
Picture jumps
you might have bad caps or the vertical output integrated circuit, try to locate the vertical ic and check the surrounding areas for bad capacitors.
good luck
[email protected]
10/23/2008 1:21:31 PM • Hitachi 53SWX10B... • Answered on Oct 23, 2008
Hitachi 53SWX10B 53" Rear Projection Television Logo
Popular Tags
31 questions posted
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Hitachi Televison & Video
Most Popular Question
hitachi 53swx10b sound starting
  • Televison & Video
