20 Most Recent TBK Timing Belt Kit Hyundai Accent 1 6l 2001 2002 2003 2004 Questions & Answers
I replaced the timing belt on a 2003 Hyundai Accent 1.6 engine. I'm having problems starting the engine. What are the steps to putting it back on time?
If by timing you mean that you aren't sure that you have the belt on the cam/crank assemblies properly, now is a bad time to mention it. This is an interference engine. Proper alignment of the crank/cam with the timing belt is critical and must be exact or serious internal engine damage will result. Even turning the engine too far without the belt properly aligned can damage pistons and valves. At this point if you didn't get it right, the damage is probably already done. For a quick check, disable the fuel pump, pull the spark plugs and perform a compression check. If it doesn't pass, take it all apart and assess the damage and repair as necessary.
11/25/2015 1:59:23 AM • TBK Timing Belt... • Answered on Nov 25, 2015
How does the iPod Nike running monitor work?
The Nike GPS monitor fits into your sneaker and you can track your progress on your iPhone or iPod with a special app. You can download the app from the iTunes app store.
http://nikerunning.nike.com/nikeplus/v1/pdf/English.pdf
11/25/2014 12:13:15 PM • Running • Answered on Nov 25, 2014
Can you put running shoes in the washing machine if they are air?
I have always washed my sneakers in the washing machine, if they have air bubbles make sure that you wash them on a cold wash and not too hot as this can cause the bubble to expand and rupture.
1/13/2013 12:44:04 PM • Running • Answered on Jan 13, 2013
My Nike air max bubble has burst can this be repaired?
It is unlikely that the bubble can be repaired but Nike does have a 2 year warranty depending on the wear and tear of the shoe, you could take them to the store you got them and see what they say.
1/13/2013 12:43:22 PM • Running • Answered on Jan 13, 2013
TBK Timing Belt Kit Hyundai Accent 1 6l 2001 2002 2003 2004 Logo
1 questions posted
Top TBK Running Experts
Gloria R. Bloomberg
Gloria R. Bloomberg
Sara Patterson
Sara Patterson
Level 1 Expert
Are you a TBK Running Expert? Answer questions, earn points and help others
View Most Popular
TBK Running
  • TBK Running
Most Popular Question
replaced timing belt 2003 hyundai accent
  • Running
