20 Most Recent
Canon NP 6050 Copier Questions & Answers
About my business...
Xerox DocuColor 3535 RC With Xp12 Feary Is the best for color & canon IR 6000 For Black & White
is Best For all.
E800
Hello
E800 means :
E800
Auto power off circuit problem. Main switch or DC controller
NP6050 false paper jam at doc feeder
When you put documents in the feeder and you push start do you see 2 black arms swing out to count the number of orignals? If yes, dose the doc tray begin to go down and then jams? If yes, you can try something.... OK, turn the copier off and move the 2 paper guides of the doc tray toward the middle. You need a #2 philip's head screw driver. Remove the 2 silver screws that will be sunk in a bit on the top of the doc tray. Once you remove the screws, remove the top part of the doc tray and you will have one connector toward the front. Unplug it and replug it back in and see if that works, if so return the 2 screws and you should be OK.
What is E34 error?
web search canon error codes cursor through listings to find your error code and solution
Np 6512
I did some research on my end about my repairs but came up empty. Sorry
Owen
6050 ERROR E006
That is a Fuser error, in particular a Fuser feed connector issue. you may need to replace the Fuser Rollers, Bushings and Bearings then go to the service menu and clear the error.
