20 Most Recent JVC AM FM CD DET FACE CAR STEREO Questions & Answers
3answers
JVC KD-S15 setup - How do I turn "Demo" Off?
press and hold the sel button....select an itenm (useing the silver button beside the volume dial).....then use the volume dial to adjust ,time , demo alot of others...then press sel button to finish.....this is straight out of the instructions...hope it helps you
5/26/2022 2:35:42 AM • JVC AM FM CD DET... • Answered on May 26, 2022
5answers
JVC KD-HDR60 has stopped responding
I had the exact same problem on my unit the other day. I spent a couple of hours trying to fix it. Did the reset button button behind the faceplate and the I couldn't get the unit on at all. I found the if you push the power/source button as soon as you put the unit on the power would turn back on, but buttons still wouldn't work. After trying several different combination, I started hitting the UP arrow button (which is the program buttons) as fast I could for about 10 seconds and the unit started working. Might have been lucky, but it worked for me.
10/24/2021 1:25:27 PM • JVC AM FM CD DET... • Answered on Oct 24, 2021
2answers
I have a jvc kd-r311 radio in my car which has
If you have a multimeter, try checking the speakers and speaker wires for shorts and/or grounds. Make sure your speaker wire has no bares spots. If the speakers and speaker wires all check out good, you may have a bad internal output ic.
8/19/2021 8:16:53 PM • JVC AM FM CD DET... • Answered on Aug 19, 2021
7answers
JVC CD player won't turn on, but will eject CD and display time.
Make sure the red wire is still connected or make sure the red wire hasn't been severed. Also, check the fuses located in the engine compartment. The red wire connects accessory terminal in the fuse block. Also check the fuses in the cabin. This fuse box is typically located on the driver's side, at knee level, next to the door panel, and underneath the dashboard. As a last resort, the unit can be taken to an authorized or factory service center.
9/11/2019 5:54:44 AM • JVC AM FM CD DET... • Answered on Sep 11, 2019
3answers
JVC KD-R610 is stuck in Protect mode
Try disconnecting your battery, reconnecting it, and resetting your stereo. If that doesn't work, the constant power (yellow wire) or ignition wire (red wire) may have come in contact with ground or isn't properly connected. Make sure everything is connected properly and try resetting your stereo. If it is still flashing "protect", the unit needs servicing Contact JVC Customer Care Center at: 800-252-5722.
8/14/2019 4:08:17 AM • JVC AM FM CD DET... • Answered on Aug 14, 2019
I have a 97 Hyundai Elantra. When all wires are
your accessory power for the radio is on the wrong circuit,wish the red wire of the radio
6/16/2019 4:23:53 AM • JVC AM FM CD DET... • Answered on Jun 16, 2019
There's a cd stuck in my jvc det face car
try disconnecting power to the radio for a while. you can do that by disconnecting the battery.
3/31/2019 8:55:12 PM • JVC AM FM CD DET... • Answered on Mar 31, 2019
How do i use and install the mounting kit
Didn't the deck come with the mounting kit and instructions? Usually they even give to a cut-out template. Please contact JVC and ask for the installation paperwork. You might consider taking it and your car to a stereo installation shop to have it professionally installed.
3/3/2019 5:36:03 AM • JVC AM FM CD DET... • Answered on Mar 03, 2019
How to set the color on my faceplate. It contnues
You're stuck in DEMO mode. When you see stereo's on display at a store it is set to a DEMO mode that cycles through colors, functions, etc so that potential customers can see the different aspects of the unit. To get it to stop changing colors you'll have to go into the menu and turn DEMO OFF.
2/19/2019 12:05:08 AM • JVC AM FM CD DET... • Answered on Feb 19, 2019
How to save FM radio
Try this, tune to the desired radio station and holdpress the station number ( 1-6) for a while, it should blink twice to confirm its storage.
Ekamave
12/12/2018 2:06:12 PM • JVC AM FM CD DET... • Answered on Dec 12, 2018
2answers
Hi My KD G396 IS
here is the manual it would help to install your device
http://www.jvc.com.au/JVCstores/PRODUCTS/357/ATTRFILE_File3/KD-G245-396%20Inst.pdf
Ifthis solution helpful/useful for you please rate the solution. THANKS FOR USINGFIXYA.
10/6/2018 6:20:31 AM • JVC AM FM CD DET... • Answered on Oct 06, 2018
2answers
Jvc Kd-s79bt
This answer is found on page 16 of manual. goto BT mode and Press and hold [MENU]. Select [BLUETOOTH]-> [DELETE PAIR]->[PHONE NAME]-> [DELETE YES]->DELETED!
5/7/2018 7:53:47 PM • JVC AM FM CD DET... • Answered on May 07, 2018
0answers
Have stereo yellow wire to battery, black wire to
I suggest you ensure the ground is made to a sensible ground point and the supplies are also good and the antenna is also properly grounded and then monitor the supply voltage and the current consumed by the radio until it begins to distort. If the voltage and current remain steady the fault is either local interference or inside the radio, probably in the tuner. If the current climbs and the voltage remains steady the fault is likely in the audio section...
11/18/2017 2:53:35 AM • JVC AM FM CD DET... • Answered on Nov 18, 2017
Jvc KD-R531 ipod
Contact JVC customer service please.
6/27/2017 4:39:20 PM • JVC AM FM CD DET... • Answered on Jun 27, 2017
Jvc KD-R210
Follow the instructions in the first column of the first page of the manual.
4/24/2017 9:24:09 PM • JVC AM FM CD DET... • Answered on Apr 24, 2017
3answers
JVC AM FM CD DET FACE CAR STEREO Logo
916 questions posted
Popular Products
Top JVC Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
 Grubhead
Grubhead
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • JVC Car Audio & Video
Most Popular Question
jvc kd hdr60 stopped responding
  • Car Audio & Video
