20 Most Recent Casio FX-115MS Plus Calculator Questions & Answers
2answers
M mod n in Casio fx991MS
there is one button ab/c beneath CALC... if u want to calculate 7 mod 4 then... u should press 7 then ab/c 4 and equal to
1, 3 ,4 which is 4*1=4 and 7-4=3 remainder...
9/18/2014 12:54:51 PM • Casio FX-115MS... • Answered on Sep 18, 2014
My calculator does not show me any decimal spaces,
If your results are coming out as fractions, press SHIFT MODE 2 to select the LineIO mode.
If your results are coming out as decimals but with not enough digits, press SHIFT MODE and then select either FIX or NORM for the display mode.
4/1/2014 5:05:59 AM • Casio FX-115MS... • Answered on Apr 01, 2014
2answers
4.7=-logka
I assume you mean b6f99112-cd6a-4c9f-8af0-ec0b8fcf8cf0.gif This equation contains two unknowns: k and a, so I cannot give you a numeric result, nor can a calculator. However, you can express k as a function of a, or a as a function of k: 9ce61ef1-5d84-4b18-a7fb-45253bbf5e1d.gif where ln is the natural logarithm base e=2.712818...
3/30/2014 12:03:29 AM • Casio FX-115MS... • Answered on Mar 30, 2014
How to calculate 24124 mod 19937 in casio fx-991Ms calculator
The MOD function simply returns the remainder that is left over after dividing the two numbers.
In this case, its possible to see quite easily that only 1×19937 can be taken from 24124 before the remainder is less than 19937. The MOD function is therefore the same as 24124 - 19937 = 4187.
In cases that are less obvious, do the division, ie 24124 ÷ 19937 = 1.210011536[34]
[The last two digits are hidden on the display but still used in subsequent calculations].
Then obtain the fractional part by subtracting 1 to give 0.210011536[34]. Then multiply the answer by 19937 to give 4187. Assuming that you haven't cleared the screen between each section of the calculation, the screen will show "Ans×19937 [=] 4187".
3/10/2014 12:38:49 PM • Casio FX-115MS... • Answered on Mar 10, 2014
Arctan
Press SHIFT then tan. The shifted function of the tan key is marked tan^-1 for inverse tangent, another name for the arctangent.
2/26/2014 10:40:41 PM • Casio FX-115MS... • Answered on Feb 26, 2014
How to adjust brightness?
Press SHIFT MODE down-arrow 6. Use the left- and right-arrows to adjust the contrast. Press AC when done. If you can't get the contrast high enough to be easily readable, the battery might be low---try replacing the battery.
2/9/2014 7:57:56 PM • Casio FX-115MS... • Answered on Feb 09, 2014
How to enter arc cos
Press SHIFT cos then the value whose arccosine you want. For example, to find the arccosine of 0.5, press SHIFT cos . 5 =
8/29/2013 6:33:18 PM • Casio FX-115MS... • Answered on Aug 29, 2013
Enter arccos
Press SHIFT then the cos key.
8/29/2013 6:32:35 PM • Casio FX-115MS... • Answered on Aug 29, 2013
Were do i find x to the power of y
It's the key marked "^", just below and right of the big circular cursor pad.
10/25/2012 3:10:44 AM • Casio FX-115MS... • Answered on Oct 25, 2012
Will not calculate numbers with decemils
The calculator is telling you that the result is 7.5 times ten to the negative 3, or 0.0075 .If you want to see the result without the exponent, change the display mode. Press SHIFT [SETUP] 6 and then specify the number of digits you want after the decimal point.The D simply tells you that the calculator is set to Degrees. All trig functions will use degrees. If you want to change this, press SHIFT [SETUP] and select 4 for Radians or 5 for Grads.
10/6/2012 5:13:47 AM • Casio FX-115MS... • Answered on Oct 06, 2012
Converet precent to decimal
Divide by 100. For example, take 40%. Divide 40 by 100 and get 0.40 .
7/30/2012 1:27:14 AM • Casio FX-115MS... • Answered on Jul 30, 2012
2answers
How do you put a
Press SHIFT MODE 1 to put the calculator into MathIO mode.
7/18/2012 7:34:56 AM • Casio FX-115MS... • Answered on Jul 18, 2012
How to do binary, octal, hexadecimal conversions in fx-991ms
Press MODE 4 to enter the BASE-N mode. Select the input base. Enter the number. Press =. Select the output base and see the result.
6/11/2012 5:34:19 PM • Casio FX-115MS... • Answered on Jun 11, 2012
I just want to know how to do ratios on my calculator
For all practical purposes, ratios involve nothing but the division of one quantity by another. Thus you use the division key. The first cited in a ratio is put in the numerator (dividend), the second named is put in the denominator (the divisor).2:3 translates as 2/3.
4/13/2012 1:02:22 AM • Casio FX-115MS... • Answered on Apr 13, 2012
How do i calculate ratios
You don't need a calculator for this. Simply multiply both the numerator and denominator by 2 to get 2/30.
4/12/2012 4:37:29 PM • Casio FX-115MS... • Answered on Apr 12, 2012
2answers
I need to find the reciprocal button the FX-115MS
The key is marked "x-superscript-negative-one" and is located just below the "MODE" key, right of the big circular cursor pad.
10/27/2011 7:06:53 PM • Casio FX-115MS... • Answered on Oct 27, 2011
How do you calculate a number to the power of x...
Assuming that you have a number already stored in memory location X, and another number (lets call it "y") that you want to raise to the power of the number in memory X, then the required calculation is: y^X=
The key presses (after entering the value y) are [^][ALPHA][)][=]
7/29/2011 5:06:43 PM • Casio FX-115MS... • Answered on Jul 29, 2011
Casio FX-115MS Plus Calculator Logo
54 questions posted
Top Casio Office Equipment & Supplies Experts
k24674
Arnie Burke
Arnie Burke
Ngoro
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Casio Office Equipment & Supplies
Most Popular Question
find x power y
  • Office Equipment & Supplies
