20 Most Recent JVC AV-32D502 32" TV Questions & Answers
manual
How to program the TV remote to work with an APEX
As far as I can remember, the original JVC remote doesn't support a DVD player. It doesn't have the necessary buttons to control the player functions. You'll need to stick with the original Apex remote if you have it, or look for a universal remote that is compatible.
7/30/2011 6:17:23 PM • JVC AV-32D502... • Answered on Jul 30, 2011
I have JVC AV-27D305 and
See the website MCM Electronics. Here, you will find an original. The other site to visit would be Matelectronics. These two companies will surely have the remote you need. Yes, sometimes you will need an original remote to fix your problem. Thanks for asking and show all hands of support!
5/2/2011 9:34:31 PM • JVC AV-32D502... • Answered on May 02, 2011
We accidentally hit some button
Hello
Closed Caption function is set to On in your JVC. look if there any button marked as "CC" on its remote control. If it is there, hit it till the closed caption function go off from your tv screen. If there is no such button found, get into its menu option, surf through, and get in to the closed caption option, set the close caption function OFF in that window. OK.
4/11/2011 1:59:23 AM • JVC AV-32D502... • Answered on Apr 11, 2011
I have a JVC D
Hi:
this commonly due to no high voltage, the horizonal deflecton circuit is not functioning, this may be due to poor solder connectins around and on the flyback transformer. The television is in need of servicing.
9/5/2010 3:20:44 AM • JVC AV-32D502... • Answered on Sep 05, 2010
Flashing timer led
There is no reset button like in the old days. You can reset the microprocessor to it's default state by unplugging the set, let it stay unplugged for 10 or more minutes. Plug the set back and it will reset itself.
You might lose stored channels and settings but they will all be reset to the manufacturers specs. This is true for anything that has a microprocessor (computer) in it.
4/19/2010 5:26:49 PM • JVC AV-32D502... • Answered on Apr 19, 2010
My JVC television doesn't turn on. When you power
The main power supply has either failed or is shutting down due to a downstream failure, the most likely place for the latter is the horizontal sweep circuit that produces the high voltage and the sweep that moves the trace across the screen. The most common failure in that circuit is often a failed 'flyback' transformer and/or the very fast, powerful, sweep transistor itself. Checking the transistor isn't technically difficult (they normally short between two of the three elements) but measuring the flyback requires some knowledge of what to expect and an inductance meter as a minimum.
If you can locate an old, still breathing, TV repair tech, I would even advise having it repaired since (check for yourself under "LCD," "plasma" or "rear projection") the modern sets will not last as long as your JVC did. If you get it repaired, put it in a dry place (with the digital converter if you have one) and keep it as a spare so you won't have to do without TV when the new 14-15 month-old set goes belly up.
12/17/2009 4:08:54 AM • JVC AV-32D502... • Answered on Dec 17, 2009
Need remote control code for Radio shack 2-in-one.
0053 is the only JVC code in the master manual
Please rate the help++++Thanks for using FIXYA
9/24/2009 11:06:41 PM • JVC AV-32D502... • Answered on Sep 24, 2009
On- timer light flashing no picture no sound.
hit the timer or program button on remote. see if that helps. your trying to get the picture up so you can turn the timer switch off. make sure tv is on. reply if you need more help
have a great day bama46 please rate
8/22/2009 2:32:45 AM • JVC AV-32D502... • Answered on Aug 22, 2009
2answers
Help ,help.
8/22/2009 2:27:18 AM • JVC AV-32D502... • Answered on Aug 22, 2009
Is this TV HD capable?
This is not an HDTV. However, that does not mean you cannot use it to view the HD channels with DirecTV, you just wont be able to view them in hi-def. Use the component inputs from the directv tuner and plug those into the proper component inputs of your JVC. Once you see the DirecTV picture on the screen, go into menu... setup (with the directTV remote) and make sure that the only resolution checked is 480i. DirecTV with 'downconvert' those cannels to standard def, and they will still look pretty good though the component connection...
... now, in answer to your next question: "What exactly do I need to view HDTV with DirecTV?"...
1. A television that will accept 720p or 1080i signals.
2. A DirecTV HD Tuner.
3. Any DirecTV service BUT you must purchase the HD pack so that they will 'unlock' the HD channels
4. The proper cables to hook in between your DirecTV HD receiver and your HD-capable TV/Monitor. You may use either HDMI or component video cables, so long as your TV will accept them. Tune your TV input accordingly. When using component video cables, you must also run a separate cable(s) for audio...
Take care,
Rob
ps. DirecTV HD tuners do not have an RF 'out'. ("coaxial or ch3/4 connection")
3/5/2009 6:58:16 PM • JVC AV-32D502... • Answered on Mar 05, 2009
NO PICTURE OR SOUND
i have the same trouble,i found sometimes i can unplug it and plug it in a few times and it will turn on but it dosnt do that even so i am taking it to a technician
6/19/2008 8:58:47 PM • JVC AV-32D502... • Answered on Jun 19, 2008
JVC 43" (109cm) HD Ready Plasma TV PD43N30A. Chunghop universal remote codes for JVC pd43n30a
Question edited for a lot more clarity, plus Chunghop not chungCHOP :>D JVC: 089, 161, 909
CHUNGHOP Universal Remote Control Codes
codesforuniversalremotes.com https://codesforuniversalremotes.com > chunghop-univer... Jul 25, 2019 - CHUNGHOP Universal Remote Control Codes ; Aiwa: 009, 057, 058 ; Samsung: 618, 619, 620, 621 ; Philips: 013, 023, 024 ; Hisense: 676, 677, 707, 898
3/20/2024 5:38:12 PM • JVC Televison &... • Answered on Mar 20, 2024
2answers
My jvc smart tv is not passing the android logo how do i fix
try unplugging the unit. Press and hold power button for 10-20 sec's then try again
3/17/2024 3:32:51 AM • JVC Televison &... • Answered on Mar 17, 2024
JVC I Art Pro AV-56WP74. It has a cracked outer screen and I can't find anywhere to replace it. I want to fix the problem.
Question edited for clarity. If is is the outer clear screen, replace it with a a sheet of Lexan Polycarbonate sheet cut to size. Lexan is bulletproof. https://www.google.com/search?q=clear+polycarbonate+sheet+cut+to+size Sears list it but no longer available. After all Rear Projection Televisions are antique dinosaurs. Technology has moved on :>D https://www.searspartsdirect.com/model/33xrqyx4kj-001758/jvc-av-56wp74-television-parts https://www.google.com/search?q=jvc+i+art+pro+av56wp74+parts Service Manual https://www.manualslib.com/manual/2744485/Jvc-Av-56wp74.html#manual ..
11/10/2023 11:43:38 PM • JVC Televison &... • Answered on Nov 10, 2023
I have Jvc receiver RX-5060 is not switching on, it is always on standby
  1. Reset the receiver: To reset your JVC RX-5060 receiver to its factory default settings, switch off the receiver and unplug it from the power outlet. Press and hold the "Power" button on the front panel for approximately 5 seconds.Then, while still holding the "Power" button, plug the receiver back into the power outlet2.
  2. Check the fuse: If your receiver still doesn't turn on, check if there's a blown fuse in the receiver.If so, replace it with a new one of the same rating3.
If none of these steps work, it's best to contact a professional or JVC's service center for further assistance. I hope this helps!
8/27/2023 7:04:23 PM • JVC Televison &... • Answered on Aug 27, 2023
JVC AV-32D502 32" TV Logo
19 questions posted
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • JVC Televison & Video
Most Popular Question
jvc television doesnt turn when power
  • Televison & Video
