20 Most Recent
Itronix GoBook III IX260 Notebook Questions & Answers
My gobook 3 gps com 4 cannot find satelites
Usually when these things stop working it has to do with the voltage getting to the receiver or the receiver itself. I suggest you have it replaced since it has probably just quit functioning. I mean the wireless card, not the gobook.
I have an Itronix IX260
Take out the memory boards. See if it boots to bios. If it does turn it off and put the memory boards back in. Should be fine after that.
My w fone sim blocked its needs puk code my cell number is 03365
PUKs, or personal unblocking keys, are used to unblock a mobile phone which becomes blocked. Mobile phones may become blocked when a PIN (personal identification number) is entered incorrectly on three consecutive occasions. In some instances, the phone may become blocked, which requires a PUK to unblock it, and in other instances, the SIM (Subscriber Identity Module) card itself becomes blocked and again will require a PUK to unblock it. Mobile phones are also blocked when they are reported stolen and if there is an outstanding payment on the account. It is important to differentiate between unblocking phones (using a PUK) and unlocking mobile phones (using another type of code). NOTE: It is a criminal offence for anyone to attempt to unblock a mobile phone, other than the network provider who put the block on the phone. If your phone has become blocked by mistake, for example you have entered the PIN incorrectly on three consecutive occasions, then you need to contact the mobile phone network operator with your details. To explain a little more, specific to your mobile phone network, You need to go to your Service providers, web site & navigate your way to the specific PUK details for your mobile phone network operator. Usually you have to Register your phone to get a PUK code.
I have itronix IX260 with loose lan connector,how
Firstly, turn off the itronix IX260 and remove the battery. Turn the system upside down while its closed and unscrew all the screws the is holding the case together.
Force in a flat screw driver into the sides of the itronix IX260, in other to get it opened. The case is clipped together. The flat screw driver will help to open the clipped sides of the case. Do not apply too much force, so that the case won't get broken.
Study the way the case is fixed in other to get it opened. Also, remove all peripherals and the the case will successfully be removed.
Its not necessary to open the screen part. But you can do so if you like.
Good luck.
I need to reset the bios super user password on an
Remove the CMOS battery from you system. Be careful, the system should be turned off before doing this.
Reinsert the battery, and the password as well as the user will be reset.
-rate if it helped you.
IX260 hard drive
Hi:
I am reasonably sure that the hard drive accessed thru the battery compartment. You remove teh battery cover, remove the battery, and the hard drive is then able to be removed.
