20 Most Recent Mitsubishi WD-65638 65" DLP HDTV Questions & Answers
My picture on my WD-65638 mitsubish dlp tv has a slight flicker that is annoying. Is my tv messed up?
There are a number of reasons this could happen and unfortunately not much that you can solve. If you have a backlight control in the menu you could try turning this down to see if the problem is reduced or cleared. This won't help you but the info may help a tech.
2/7/2018 7:44:13 AM • Mitsubishi... • Answered on Feb 07, 2018
Third time replacing 65" mitsubishi dlp bulb ?
Use Osram or Phillips bulbs Check for blocked air flow Always allow TV to complete cool down with plug in wall Check/Replace ballast
8/22/2016 4:40:08 PM • Mitsubishi... • Answered on Aug 22, 2016
65 in wd-65638 looks like dirt inside the scrin
Its not dirt, the light engine is failing and this part is not cheap.
2/6/2016 5:45:43 PM • Mitsubishi... • Answered on Feb 06, 2016
Humming Noise from TV
There are multiple fans and a high speed light device and a ballast in that television. All could be causing this.
2/5/2016 11:02:52 PM • Mitsubishi... • Answered on Feb 05, 2016
Replaced bulb, now tv comes on for 1-2 minutes, goes funky and turns to a red light on power.
Possibly replacement lamp is wrong power, size, type, etc., or may be defective. Try another lamp. Also, clean and vacuum cooling fans and filters. One fan is squirrel cage type, the other is a pancake type. Lubricate each fan with a tiny drop of Z-Max or other light oil on each motor bearing. Regards.
1/5/2016 5:09:44 PM • Mitsubishi... • Answered on Jan 05, 2016
Why is there no picture and it turns off?
Replace lamp. Regards.
1/5/2016 5:06:21 PM • Mitsubishi... • Answered on Jan 05, 2016
What would cause my 65" WD 65638 TV to power on normally but after a few minutes it will start making a squealing noise in the back and the picture will start to get fuzzy and distorted an than shut i
that squealing noise is probably the color wheel & if it is available it is as an assembly. will need to contact local servicer for est.
1/3/2015 5:45:11 AM • Mitsubishi... • Answered on Jan 03, 2015
Black mark on t.v. Screen
It sounds like you have a separation issue. The material that the screen is made out of is layered on top of each other. What happens is it separates and causes the distortion/discoloration. When you press on it you are actually pushing it back together like a fly paper that doesn't want to stick anymore. There is not a fix for this other than a new tv.
8/23/2014 1:28:57 AM • Mitsubishi... • Answered on Aug 23, 2014
Mitsubishi WD-65638 turns itself off and I see no status codes afterwards
Press menu and input on front of TV for 5 seconds. Green light will flash two digit code 5 times. '12' is no error(no problem.)
6/10/2014 7:34:05 PM • Mitsubishi... • Answered on Jun 10, 2014
Tv shuts off
Likely a bad lamp or a color wheel not starting.
5/8/2014 3:32:55 AM • Mitsubishi... • Answered on May 08, 2014
0answers
Ballast
Be the first to answer 5/4/2014 3:50:33 AM • Mitsubishi... • Posted on May 04, 2014Be the first to answer
Mitsubishi WD-65638 65" DLP HDTV Logo
76 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
WD Mitsubishi
  • WD Mitsubishi
Most Popular Question
mitsubishi wd 65638 dlp tv error codes
  • Televison & Video
