20 Most Recent
Troy Drywall and Panel Hoist with Extension DPH1116 Questions & Answers
Mold on drywall
You need to investigate the cause. Where there is mould, there is damp...
If it was through the previous occupiers using things like tumble dryers, irons etc in enclosed spaces without sufficient ventilation then that's one thing. Damp on walls always needs investigating though to ensure the house is structurally sound. Have you had an extended survey done?
4/30/2020 5:26:16 AM •
Drywall
Answered
on Apr 30, 2020
I need help finding a stub behind drywall
The stud finders are not expensive but you can sometimes use a magnet to find the nails. Also you might try shining a flashlight across the wall. The putty put over the nails will sometimes show up. Last resort is to tap on the wall and try and hear the areas that have support under them.
7/19/2019 4:31:44 PM •
Drywall
Answered
on Jul 19, 2019
Is there a tool that will make it easier to cut
Circles are hard to make, I had a lot of trouble when we decided to put recess lighting into the whole house. I wasn't able to find a tool that does all the cutting for you but what worked really well for me was a Goldblatt Drywall Circle Cutter. It doesn't cut all the way through the drywall, it just scores it so that all you have to do is cut from the center of the circle out to the edge and then snap off the pieces. Saves you tons of time trying to get those round edges to look perfect!
7/17/2019 12:17:44 PM •
Drywall
Answered
on Jul 17, 2019
How to fix 1 inch holes in drywall
Wow all those answers are ok but easy way is to wad up a piece of paper larger than the hole-force piece of that paper into hole slowly not to force into cavity behind just slightly flush then stop-take a putty knife and float with drywall compound you can get a small container of that compound at walmart even-then repeat and sand between coats until you are flush and smooth-if there is a texture then on last coat take a roller and run it thru the wet compound
12/17/2017 10:27:47 AM •
Drywall
Answered
on Dec 17, 2017
Cutting Drywall Like a Pro
Cutting drywall is one of the more easy cuttings that you will do when remodeling your house although you hear all kinds of horror stories of people making huge mistakes and having to re-hang drywall or use exorbitant amounts of putty to fix mistakes. Following just a few simple tips you can master the task of cutting drywall.
Most of the cuts that you will be doing will fall under the category of score, snap, cut. Because dry wall is fairly easy to cut, for a majority of cuts you will just need a scoring knife with just enough pressure to cut the paper and then you will be able to snap the drywall then you have to cut the paper on the back side and you are done.
For the major cutouts that you will be doing like doors and windows, the best way to go about doing them is to measure and cut the boards before you hang them. Its best to have someone help you hold the board in place.
There are two main types of saws that you will use a drywall rip saw and a keyhole saw. They each have their purpose and they should only be used for the purposes that they are meant for. The keyhole saw is for small cuts like holes for light fixtures, outlets and switches while the rip saw is for cutting drywall down to size like for doors and windows.
Once you have mastered the basics of cutting drywall you will be able to do more advanced home repairs and will spend less time worrying about cutting out pieces of drywall.
Paint bubbling and peeling soon after painting a newly rendered wall........how do we fix it?
Sorry for the paint peeling and bubbles. It's not the drywall tape that has bubbles... right? Paint can react like this when it is applied over a sanded wall that has not been cleaned and still has a layer of drywall dust on it. When primer is applied to the wall, it is best to use something to push the paint on the surface to combine the dust with the paint. This could be done using a paint pad but should be more than just rolled on. The paint needs to mix with the dust and stir it in with the paint so the paint get under the dust. You might try thinning the paint a little to allow for better attraction to the wall. So now how do you repair this? By scraping the loose paint off and starting with a new coat. You know. it could also just be bad paint.
3/1/2015 2:30:12 AM •
Drywall
Answered
on Mar 01, 2015
