20 Most Recent
Zenith ZN401 Remote Control Questions & Answers
Don't see the Remote control
0121 0009 0050 0078 0091 0138 0059 0131 0038 0111 0134 0153 0064 0004 0135 0226
0227 0245 0247 0252 0266 0288 0310 0338 0358 0023 0058 0039 0001 . These are the universal remote codes for Zenith TV. Just buy one remote control, which have any of this codes in its code list. you can get this detail from attached code list with the remote control. Almost all brands of remote will have codes for Zenith TV. Needn't to bother about the Brand name of the remote. Codes are to be checked.
I NEED THE TOSHIBA TV
hi,
Try the following codes one by one for your Toshiba telivision.
110, 111, 134, 171
ok
My zenith CD/DVD duplicator LCD light on but no ready
If the LCD light on your Zenith CD/DVD duplicator is on but it is not showing as "ready," it is possible that there is an issue with the duplicator's internal components or settings. Here are a few troubleshooting steps you can take to try and resolve the issue:
Check the disc trays: Make sure that all of the disc trays are closed properly and that there are no discs stuck inside the duplicator. If a tray is open or a disc is stuck, the duplicator will not be able to operate properly.
Check the power source: Make sure that the duplicator is plugged into a working power source and that the power cable is securely connected to the duplicator. If the power source is not providing enough power, the duplicator may not be able to operate.
Check the settings: Check the duplicator's settings to ensure that it is set up correctly for the type of disc you are trying to duplicate. For example, if you are trying to duplicate a DVD, make sure that the duplicator is set to duplicate DVDs and not CDs.
Reset the duplicator: Try resetting the duplicator by unplugging it from the power source for a few minutes, then plugging it back in and turning it on. This can sometimes resolve minor issues with the duplicator's internal components.
If none of these steps resolve the issue, it is possible that there is a more serious issue with the duplicator's hardware or software. In this case, it may be best to contact Zenith customer support or a professional technician for further assistance.
