20 Most Recent
Bose Lifestyle 28 System Questions & Answers
Replacing cones on my bose ps28 series II
Use a small flat screwdriver to lift the front grill from the sides.After detaching the grill,unscrew the plastic guard to have access to the speakers and then unscrew the speakers.
I just replaced the dvd in my bose lifestyle 28
Replaced the DVD? Did you replace the mechanism, or the entire media center?
If you replaced the dvd mechanism, you might be out of luck getting firmware to support the rest of the hardware.
If you mean that you replaced the media center, the firmware is available as part of a normal software update disc through Bose. To check sw and fw-> when the system is off, press and hold 'enter' on the media center and tap the 'store' button until you see "console sw" on the display. Same with fw.
Bose - Custom EQ Error: 10
Hi, I have just had the same problem and the advice from BOSE was to turn everything off and disconnect the sub from the main unit, wait 10 mins and turn everything back on, making sure to turn the sub on first.
As it happens i then noticed I had connected the sub via the BOSE link speakers plug to the main unit rather than the correct "MAIN" socket. - so if you are reading this you know I am a fool! But the sound now works.
Basically BOSE confirmed the reason for error 10 is that the main unit is not detecting the sub and speakers.
Anyway, I hope my foolish mistake, helps save time and blushes for anyone reading this link.
J.
My remote stopped working
First check the batteries. Then clean all of the connections. If still nada then check out the remote by pointing it at an am radio set to 600khz about 6 inches away and listen for beeping when you press any button. If nothing happens then the remote is trashed and needs to be replaced.
I have the bose av28
No, only the Bose remotes will work with it! Bose doesn't let any other remote to work on their systems.
