20 Most Recent
Konica Minolta magicolor 2300DL Laser Printer Questions & Answers
Magicolor 2300dldl fatal error code 14h
The second transfer roller might be missing. Is not properly installed. If you open the printer you will see a roller made of sponge like material. That is the second transfer roller. Replace it if above does not work also ensure the transfer belt is properly installed. that is across from it in the machine.
Can not get this to recongize toner?
did you change toner from printer menu or rotate toner rack manually ??? this printer toners must be changed from printer menu, because printer counts toner there is no chip on toner.
Fatal error 17H
FATAL ERROR CODE 17H / SERVICE CALL 17 TONER RACK: Incorrect developing rack rotation
<Remedy>
Electrical components for detection of the malfunction
Rack motor (M2)
Rack clutch (CL1)
Rack home position sensor (PC4)
Master board (PWB-A)
Controller control board (PWB-P)
Rather than try to explain in more detail i can forward you the service manual (4.17mb) if you update with an e mail address
Service Call 15H
FATAL ERROR CODE 15H / SERVICE CALL 15 XFER BELT: Incorrect pressure
by or separation from the transfer belt cleaner
something wrong with the transfer belt
