20 Most Recent Minolta DiALTA Di350 Laser Printer Questions & Answers
Codice c0500
Sir/mam, First open the right side cover where the image unit is located. Check the two latches that latch the door ensure they are not broken, especially the rear one. Then get a paper clip and stick the clip in the small hole on the right side of the control panel it will touch a switch. The control panel will go thru some screens when you see the screen with the copiers on it on the left side of the screen in the middle you will see a small "." When the dot appears touch 3 button. Then the machine will continue to the code screen. Press the Utility button you should see a new button "Maintenance Mode" touch it then touch trouble reset. The machine will again go thru screens will see the"." again do nothing. Should go ready to Copy. If the code comes back do not reset, you are messing with the Fuser the Hot part. Continuing to reset without a technician looking at and or replacing it, the fuser can catch on fire and that would ruin a perfectly good day. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
3/12/2017 7:32:27 PM • Minolta DiALTA... • Answered on Mar 12, 2017
How do i print via computer on minolta di350
do you use windows 95 or at best xp? you can try this site. Self Help Product Support Konica Minolta Business Solutions Inc Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
11/21/2015 11:39:57 PM • Minolta DiALTA... • Answered on Nov 21, 2015
Dialta di350 users manual where to get one
Self Help Product Support Konica Minolta Business Solutions Inc try this you have a legacy Minolta machine which is now konicaminolta mite try this site also Service manuals electronic components datasheets and equipment schematics... Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
11/21/2015 11:24:11 PM • Minolta DiALTA... • Answered on Nov 21, 2015
Error c1038
The system fails in checking initial engine connection. When the Power Switch is turned ON. #2 The system succeeded in checking initial connection when the Power Switch was turned ON; then it fails in rechecking initial connection through the execution of a software reset when a communications error occurs during operation. 1. Check the connection between Master Board and MFB2 Board. 2. Reset the malfunction and turn OFF and ON the Power Switch. 3. Change MFB2 Board. Change Master Board. So will check each connector to each board, one at a time check for a bent pin pins are on the board connector. then re-seat each connector properly, worse case bad control board, doubt you can find a board a very old legacy Minolta Machine, try this site Precision Roller Printer Toner Cartridges Parts and Supplies Office... Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
11/21/2015 9:53:25 PM • Minolta DiALTA... • Answered on Nov 21, 2015
We have a Minolta Di552
Has the developer been replaced? If not reset counter for developer without replacing the developer is not good. Because the copier works based on the counters. If you reset the counters without replacing the require items then the copier will adjust certain voltages to certain items such as the drum and developer system as those they are new because you reset the counters when in fact he developer is old and so might be the drum which can cause codes and image problems. If the developer was replaced where the counters cleared !ST!!!!!!!!!!!!!!! and was the required F8 checked run? after installing. Also was the drum removed and the sensors cleaned by brush NO Vacuum cleaner. Static Electricty can destroy the the sensors. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
11/14/2015 10:29:41 PM • Minolta DiALTA... • Answered on Nov 14, 2015
A minolta di250 gave the error message
Then replace the image unit open the right side of the machine remove the image unit with the two handle and replace with a new one, Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
3/1/2015 8:49:37 PM • Minolta DiALTA... • Answered on Mar 01, 2015
Machine trouble c0501
First check the right side cover where the image unit is located. Check the two latches that latch that door are not broken especially the rear one. Then get a paper clip and stick the clip in the small hole on the right side of the control panel it will touch a switch. The control panel with go thru some screens when you see the screen with copiers on it on the left side of the screen in the middle you will see a small "." when dot appears touch 3 button. Then the machine will continue to the code screen. Press the utility button should see a new button "Maintenance Mode" touch it then touch trouble reset. The machine will again go thru screens will see the"." again do nothing. Should go ready to Copy. If the code comes back do not reset you are messing with the Fuser the Hot part continue reset without a technician looking at and or replacing it can catch on fire that would ruin a perfectly good day good luck Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/22/2015 5:25:12 AM • Minolta DiALTA... • Answered on Feb 22, 2015
Code error C0F32
Replace the drum and developer, make sure it is done right, clear counters first be for removing the old image unit, replace drum, developer, and cleaning blade, the reinstall run F8 should be good to go web site below for parts Precision Roller Printer Toner Cartridges Parts and Supplies Office... Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/22/2015 5:11:39 AM • Minolta DiALTA... • Answered on Feb 22, 2015
Error co998 on di 5552
Check the bottom draw for jam or paper behind it. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/22/2015 2:52:53 AM • Minolta DiALTA... • Answered on Feb 22, 2015
How to reset the massage(change
Replace the Image unit that will Do it. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/22/2015 1:02:04 AM • Minolta DiALTA... • Answered on Feb 22, 2015
Di350 error code cof32
Replace the image unit. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/19/2015 12:34:07 AM • Minolta DiALTA... • Answered on Feb 19, 2015
Minolta di35lf
What about it sir/mam? Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/18/2015 11:24:40 PM • Minolta DiALTA... • Answered on Feb 18, 2015
I need driver for windows vista for dialta di350
Adriana sorry that machine can not use that driver see for your self check this web site Self Help Product Support Konica Minolta Business Solutions Inc Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/18/2015 11:10:38 PM • Minolta DiALTA... • Answered on Feb 18, 2015
Dialta 351
YES there is a utility program that has to be sent to the print controller on the machine Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/16/2015 5:51:04 PM • Minolta DiALTA... • Answered on Feb 16, 2015
How to fix error code C00500 on dialta 350
First check the right side cover where the image unit is located. Check the two latches that latch that door are not broken especially the rear one. Then get a paper clip and stick the clip in the small hole on the right side of the control panel it will touch a switch. The control panel with go thru some screens when you see the screen with copiers on it on the left side of the screen in the middle you will see a small "." when dot appears touch 3 button. Then the machine will continue to the code screen. Press the utility button should see a new button "Maintenance Mode" touch it then touch trouble reset. The machine will again go thru screens will see the"." again do nothing. Should go ready to Copy. If the code comes back do not reset you are messing with the Fuser the Hot part continue reset without a technician looking at and or replacing it can catch on fire that would ruin a perfectly good day Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/8/2015 12:59:15 AM • Minolta DiALTA... • Answered on Feb 08, 2015
CODE COF 33
With place the image unit, on the right side of the machine pull the image unit with the two handles and re-install a new one try below web site to order one Precision Roller Printer Toner Cartridges Parts and Supplies Office... Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/8/2015 12:29:05 AM • Minolta DiALTA... • Answered on Feb 08, 2015
Driver for minolta dialta di250 for windows 7
NOT going to find any!!! That machine at best can use Windows 95 or XP . The machine is a legacy Minolta now Konica Minolta check below . Self Help Product Support Konica Minolta Business Solutions Inc Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/8/2015 12:10:20 AM • Minolta DiALTA... • Answered on Feb 08, 2015
C13co code erreure minolta di350
Image unit is bad. Replace the image unit with a new one did you have some replace the developer and the drum. Then they for got to do one other important thing. THE FUSE! Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/7/2015 10:10:20 PM • Minolta DiALTA... • Answered on Feb 07, 2015
Minolta DiALTA Di350 Laser Printer Logo
36 questions posted
Top Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Daniel Blask
Daniel Blask
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Minolta Office Equipment & Supplies
Most Popular Question
error code occur ed
  • Office Equipment & Supplies
