20 Most Recent
Minolta DiALTA Di250 All-In-One Laser Printer Questions & Answers
Cant find reset area getting error code c0500
First open the right side cover where the image unit is located. Check the two latches that latch the door ensure they are not broken, especially the rear one. Then get a paper clip and stick the clip in the small hole on the right side of the control panel it will touch a switch. The control panel will go thru some screens when you see the screen with the copiers on it on the left side of the screen in the middle you will see a small "." When the dot appears touch 3 button. Then the machine will continue to the code screen. Press the Utility button you should see a new button "Maintenance Mode" touch it then touch trouble reset. The machine will again go thru screens will see the"." again do nothing. Should go ready to Copy. If the code comes back do not reset you are messing with the Fuser the Hot part. Continuing to reset without a technician looking at and or replacing it, the fuser can catch on fire and that would ruin a perfectly good day.
if you need new fuser try this site
Precision Roller Printer Toner Cartridges Parts and Supplies Office... Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/normanj_7893313f0751935f
L cant rest my copier D125if
First check the right side cover where the image unit is located. Check the two latches that latch that door are not broken especially the rear one. Then get a paper clip and stick the clip in the small hole on the right side of the control panel it will touch a switch. The control panel with go thru some screens when you see the screen with copiers on it on the left side of the screen in the middle you will see a small "." when dot appears touch 3 button. Then the machine will continue to the code screen. Press the utility button should see a new button "Maintenance Mode" touch it then touch trouble reset. The machine will again go thru screens will see the"." again do nothing. Should go ready to Copy. If the code comes back do not reset you are messing with the Fuser the Hot part continue reset without a technician looking at and or replacing it can catch on fire that would ruin a perfectly good day
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
How to reset the co500 error code from my minolta
For a new fuse try this site for a start
forf
