20 Most Recent Rangemaster Classic 90 (Electric) Kitchen Range Questions & Answers
2answers
How do I dismantle a rangemaster cooker handle
The pipe should just pull out of the brackets. Spin the bracket whilst pulling away from the pipe..
10/14/2023 5:38:32 AM • Rangemaster... • Answered on Oct 14, 2023
How to change the electric fan.right hand oven?
My fan only worked for 3 weeks and its not working now.I swapped fans other they both only worked for 3 weeks.
2/23/2018 8:22:27 PM • Rangemaster... • Answered on Feb 23, 2018
Don't know what electricity supply is required
Emmet in luton: what fuse does a rangemaster 90 duel fuel need?
5/8/2015 9:17:36 PM • Rangemaster... • Answered on May 08, 2015
0answers
0answers
0answers
0answers
Cooker is tripping the main RCD of the house. Have disconnected the element in the plate warmer to test but it still trips the house breakers when plugged back in. (Gas model)
May be a problem with the wire in side or on the plug that is blowing the house fuse get it checked by someone or pat tested
1/21/2014 2:59:38 PM • Rangemaster... • Answered on Jan 21, 2014
Front burner , yellow, flaring flames and sooty pans
Sounds like the front burner gas jet holes are either blocked in places or the gas regulation (air/gas) mix to that burner needs adjusting. Try removing the hub where the gas burns from and cleaning each hole with something like a paperclip and then blowing through it to expel any particals.
12/25/2013 2:43:14 PM • Rangemaster... • Answered on Dec 25, 2013
Clock / oven not working
The display control board may have failed, check for 110v at molex connection, next look for a circuit fuse on the control board. If the above is good, replace control board from eBay.
12/22/2013 7:29:54 PM • Rangemaster... • Answered on Dec 22, 2013
My ignition switch won't work - why?
What is the complete model number of the unit?
4/27/2013 5:02:33 PM • Rangemaster... • Answered on Apr 27, 2013
Oven light Switch broken on the Rangemaster Classic 90 Cooker
What is the model number of the unit?
11/13/2012 1:01:53 PM • Rangemaster... • Answered on Nov 13, 2012
Rangemaster grill remains hot when switched off.
Check the thermostat and Power button...
9/18/2012 9:36:29 AM • Rangemaster... • Answered on Sep 18, 2012
90 questions posted
Top Rangemaster Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Rangemaster Kitchen Ranges
Most Popular Question
gas flame in oven leisure classic 90
  • Kitchen Ranges
