RegCure has done it again!
pls follow these steps >>
remove RegCure from Add/Remove programs in Control Panel then exit the program
click the start button, then Run and in the dialog box, type "msconfig" (without the qoute) and press ok
in the System Configuration Utility window, select the startup tab
uncheck the box with the RegCure entry then click apply and ok, then choose 'exit without restart'
download and install this (Absulutely) free utility >>>
http://www.ccleaner.com/
first run Cleaner (click the cleaner button / analyze / run cleaner
second Registry (click Registry button/ scan for issues / fix selected issue
no need to back-up changes just select fix selected issues
when done restart your computer
when a message box appear regarding the system configuration, just click on the box which says 'do not show this message again and click OK
hope this solves your problem
if problem persists see me in YM
[email protected]
