20 Most Recent
Mr Gasket Timing Cover Chevrolet El Camino Elcamino 75 Questions & Answers
How do i remove thetiming cover on a 2004 chevy trailblazer?
If you do not have a 2.8 V6, then it is a V8 or the V6 that is the same as V8 with 2 cylinders off. This type you have to remove the fan, water pump, the bolt in center of the crank shaft, and the harmonic balancer that the pullys bolt to. You can loosen the oil pan bolts to free the timing cover after removing its bolts, or force it off and cut the tab on both sides to put it back on when done with timing chain/cam. use black RTV sealant with a new gasket on the cover and the rubber seal on the pan. I've done this for years instead of dropping the oil pan.
Spark@fuel,new timing belts,but it will not
If you have Spark and Fuel There is only two things thatwill be the problem.1. Start CRYING the timing marks were not properly alignedwhen the belts were installed.2. The Distributor is not installed with the rotterpointing to the number 1 sparkplug wire terminal with the number 1 piston attop dead center, and on the compression stroke. Compression stroke means theintake and exhaust valves are both closed and the piston is at the top of thecylinder. To get the piston in proper location at the proper time, remove thenumber 1 sparkplug use the starter and just bump the starter until the timingmark on the harmonic balancer is located close to the timing tab mounted on theengine. To get the balancer mark to line up with the the timing tab, don'tcrank the engine just bump the starter each time so the balancer mark only rotatesa short distance at a time. With the balancer mark close to the ZERO point onthe tab take a stiff long peace of wire, I say long wire, I mean one that will notfall down in the cylinder to where it can't be retrieved without removing the cylinderhead. Use the wire to feel inside cylinder to see if the piston is at the topof the cylinder. If it isn't rotate the balancer one revolution and feel forthe piston again. When the piston is at the top with the mark on the balancer alignedwith the tab on the engine, remove the distributor cap locate the number 1sparkplug wire tower on the cap replace the cap on the distributor making sureit sets down properly the cap has a tab made on the mounting edge that mateswith a notch in the distributor housing. Make sure they line up. Note thelocation where the number 1 sparkplug tower is located you can use a peace ofchalk an make a mark on the side of the distributor housing indicating wherethe rotter should point to. Before removing the distributor housing from theengine notice where the vacuum canister is pointing so when the distributor isproperly timed the canister will be pointing in the same location. Make surethe distributor gasket is in place before installing the distributor. When installingthe distributor the rotter will rotate in the distributor housing as it isinserted in the Cam Shaft Gear, on some automobiles there is only one place thedistributor will completely go in to the distributor hole and let the base ofthe distributor mate up with the top of the hole surface. If the rotter is notpointing to the proper place continue removing and turning the rotter a little untilwhen the distributor is properly seated the rotter is properly alighned. Continue removing and installing the distributoruntil the rotter points to the mark you made on the distributor housing and atthe same time the distributor housing is setting on the gasket not about aquarter of a inch from bottoming out.
How to reset automatic sliding door on chevy venture van
The rear side door actuator control modules monitor the power sliding door positions at all times. Whenever the battery positive voltage supply to a rear side door actuator control module has been removed or the on-board diagnostics have been activated the power sliding door system(s) must be re-initialized. Re-initialize the right or left power sliding door systems using the following steps:
- Turn the ON/OFF switch for the power sliding door system to be re-initialized to the OFF position.
- Manually open the power sliding door completely.
- Manually close and latch the power sliding door.
- Turn the power sliding door ON/OFF switch to the ON position.
- Open the power sliding door completely using the B-pillar or overhead console OPEN/CLOSE switch.
- Close the power sliding door completely using the B-pillar or overhead console OPEN/CLOSE switch.
9/9/2022 4:43:40 AM •
Chevrolet...
Answered
on Sep 09, 2022
Check engine light on says p2000 on code reader
The code is: P2000 NOx Trap Efficiency Below Threshold Bank1 and I do not know what that is unless it has something to do with the oxygen supply to the engine. Sorry I am not much help.
10/30/2015 6:24:22 PM •
Chevrolet...
Answered
on Oct 30, 2015
