20 Most Recent
Nokia 2220 Cell Phone Questions & Answers
I forgot my nokia 2220s security code
I forgot my Restriction Code, when i turn the phone on it always ask fo the code Please help me :(( Phone IMEI: 354953/04/417136/5 my phone is Nokia 2220s Thanks!
Nokia 2220 slide my restricted code is not working at all why??
Try the other method:
1.Turn it on with a non accepted sim card. There should be a message appearing that the sim card is restricted
2.Then, press ok in able to enter the code #pw+CODE+1# since you are from Canada try this code and press ok
3. You must replace code we the unlock code that was sent to you.
How to unlock the security code of nokia 2220s
Hello:::::::::::::defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will Solved
2220 Nokia phone Restriction reset
Hi, If the Nokia 2220 is network restricted you need not reset t. You must enter the unique unlock code to remove network restriction. You can get the restriction code from
www.unlocking4u.com/nokia-2220/rs6wp9/ at affordable cost. If your Nokia 2220 is phone locked you can do a master reset. You can get the master reset code from any online site.
Free unlocking code for nokia2220s
Hi are you looking for network unlock code to unlock your Nokia 2220s mobile from network provider then free codes are not available for your mobile model so better purchase code from some other reliable paid providers like
ProUnlocking.com for affordable cost .You first check that whether the code is available for your country and network provider .If yes then pay for it and unlock your phone then freely use it with any GSM sim .
I put a security code
my handset is nokia asha 220 could not remember the security code. what to do now. guide me. thankyou. imei no is 359592053239369
Nokia 2220 showing test mode screen..what to do to
Hi mmurtazas,
This usually means that your phone as been dropped in water or dropped too hard on the floor.
This means thats your phone is under caution mode.
you need to take it to a nokia dealer shop and get it fixed.
but i highly recommend for you to buy a new one as getting it fixes is very expensive.
I hope this helps.
My nokia 2220s with sim card inserted, keeps
Take your Nokia into your cell service provider and ask them to help with the sim card problem. they may simply replace the sim card for you. (AT&T will do it for free, IF you are a customer.)
